Injector voltage problem [fixed]
03-25-2016, 07:54 AM
Lightbulb RE: Injector voltage problem
Is the car running rich or lean ? What do the plugs look like ?
What happens if you try to rev the engine when it is running on three ?
Does it rev or does it choke and die ?
What I'm thinking is that this may be a fuel issue rather than an electrical
issue. Like a pump that is on its last legs and can't supply enough fuel for
four injectors without leaning out so much that the engine will no longer run.
Never actually known of this happening, but theoretically it is possible Smile
Cheers... jondee86
Messages In This Thread
Injector voltage problem [fixed] - d3nso - 03-23-2016, 07:41 PM
RE: Injector voltage problem - Bean - 03-23-2016, 11:23 PM
RE: Injector voltage problem - d3nso - 03-23-2016, 11:58 PM
RE: Injector voltage problem - Project D - 03-24-2016, 05:45 AM
RE: Injector voltage problem - jondee86 - 03-24-2016, 08:20 AM
RE: Injector voltage problem - d3nso - 03-24-2016, 10:26 AM
RE: Injector voltage problem - jondee86 - 03-24-2016, 10:17 PM
Injector voltage problem - d3nso - 03-25-2016, 12:54 AM
RE: Injector voltage problem - jondee86 - 03-25-2016 07:54 AM
RE: Injector voltage problem - d3nso - 03-25-2016, 11:10 AM
RE: Injector voltage problem - Bean - 03-25-2016, 03:00 PM
RE: Injector voltage problem - d3nso - 03-25-2016, 05:48 PM
RE: Injector voltage problem - Bean - 03-25-2016, 08:51 PM
RE: Injector voltage problem - d3nso - 03-25-2016, 09:13 PM
RE: Injector voltage problem - Nakilad - 04-01-2016, 11:54 PM
RE: Injector voltage problem - jondee86 - 04-02-2016, 07:01 AM
RE: Injector voltage problem - d3nso - 04-03-2016, 12:39 PM
  stock injector deadtime for 4age 20v silvertop/blacktop injector ditn 1 7,679 02-20-2016 11:48 AM
  removing light switch ? (fixed) MC_JP 10 21,581 09-18-2014 05:16 PM
Last Post: MC_JP
  Injector sizes info ZaX 19 43,638 07-17-2013 01:54 AM
Last Post: jondee86
  pink injector resistance Apsogos 2 5,448 10-01-2012 09:00 AM
  4agZe problem solved - 99% IC problem Okami 41 48,966 07-12-2012 04:49 PM
Last Post: Okami
