Ignition Coil - It worth the money upgrade it?
06-04-2007, 04:15 PM
As the subject says...
As my car has 240.000 Km should i replace the ignition coil? How can i test it?
If it is necessary to replace it, should i replace by an original one or there are better after market coils available?
Keeping the AE86 alive!
06-04-2007, 04:26 PM
Depends on the money you want to give!The best solution for me is to built a coil-on-plug system, but it will cost you....
JapanPower
UoP Racing website
UoP Racing videos
06-04-2007, 07:00 PM
No, the car is for road purposes and some trackdays.
So, nothing too expensive or sophisticated...
06-04-2007, 10:05 PM
I think you only really need to replace it once it starts going bad.. (which is something you would probably notice). If you do feel the need to find out if there is any performance to be gained by an aftermarket coil, just get yourself an uprated MSD coil or something similar...will be much easier to install then a completely different setup (eg. coilpacks/coil-on-plug).
06-04-2007, 10:17 PM
Well, i checked today the resistance values as indicated in the 4AGE Repair Manual and the values are within the specifications.
So and for now, i will keep the original ignition coil.
Tomorrow i will check the distributor, specially the rotor and the cap.
06-04-2007, 10:20 PM
Just replace those two..always a good idea and cost almost nothing.
06-04-2007, 11:07 PM
had some problems with running and needed to change the coil plugs etc. (to the engine from the igniter)
06-05-2007, 08:12 AM
robokill Wrote:had some problems with running and needed to change the coil plugs etc. (to the engine from the igniter)
Yeah but your engine ran over 300k Wink
  Ignition switch plug and wires Blaze0010 3 1,448 11-25-2024 12:29 PM
Last Post: Blaze0010
  Smallport coil totta Crolla 2 2,445 08-12-2022 11:03 AM
Last Post: totta Crolla
  20v Silvertop stock ignition timing and fueling maps Lykowsky 5 15,322 07-18-2019 03:52 PM
  How to test coil with igniter DJexor 2 9,058 03-22-2018 10:01 AM
Last Post: Project D
  Radiator oem or upgrade on racecar? Jimmi The Kid 5 6,744 06-23-2017 05:21 PM
Last Post: pack
