Igniter / Coil problems
12-25-2007, 06:34 PM
Does anybody know how to test igniter (on the coil) to see is it working?
And did anybody fitted igniter and the coil from RedTop 4AGE (AE92 GTi) to the BlueTop 4AGE, because they are different.
Car died on me last weekend, and after checkng everything I found it hasn't got voltage from the coil to the distributor, and no spark on the spark plugs because of that.
I ran diagnostic and it says no RPM signal (6 flashes). Manual just says change the igniter, and it isn't very easy to find another...
I tested resistance of the coil and pickup cols in the distributor and everything checks up fine. Also checked battery voltage to the coil and igniter and everything is fine (so ignition fuses and engine main relay are fine).
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
12-26-2007, 02:30 AM
You could try this (shamelessly lifted from http://www.toyspeed.org.nz) to test
the igniter output function :
Quote:To test the wiring.
1. Unplug the engine wiring loom from the ECU.
2. Turn the ignition ON.
3. Use a test light with about a 12v 4watt bulb. Clip the lead onto
a 12V positive supply. Touch the probe of the test light onto the
IGN1 wire in the ECU plug (the wire that goes to the igniter).
The coil should spark as you make and break the circuit with the
testlight. If not, then you have a wiring, coil or igniter problem.
Just to reinforce... Do this test with the ECU unplugged.
Do not probe power into the ECU. Probe it into the plug you have
pulled out of the ECU.
This test applies a low level signal to the igniter trigger circuit, which
in turn switches the coil to produce a spark. It does not check the
igniter flyback signal, which confirms to the ECU that an ignition event
has occurred.
Cheers... jondee86
12-26-2007, 12:17 PM
Download the diagnostics manual and follow the appropriate chart
http://www.aeu86.org/index/technical-ae8...topic=5158
12-27-2007, 09:44 PM
Wow !!! Good resource parrot Thumbs up! I hadn't picked up on that before. Much
better to have the factory information rather than just be guessing what
signals go where and why Confused
Cheers... jondee86
12-27-2007, 10:32 PM
parrot Wrote:Download the diagnostics manual and follow the appropriate chart
I did allready ... Wink
Little update; it isn't the coil/igniter... a changed that for a test and it works on another car.
So it's pick up coils in the distributor aka cam position sensor who tells the ECU RPM of the engine.
12-28-2007, 03:33 AM
Failing pickup coils are a common problem. Often shows up when the engine bay is hot and goes away when it cools down. Eventually they packup all the time.
If you don't already have one, a very good idea to add a heat shield to the distributor.
  Coil charge time totta Crolla 0 865 01-23-2026 07:27 AM
Last Post: totta Crolla
  Smallport coil totta Crolla 2 3,899 08-12-2022 11:03 AM
  Big wheel problems gh0st 16 15,717 11-15-2021 10:51 PM
Last Post: gh0st
  Starting problems 4-AGE kouki Hanzo 3 5,050 08-31-2021 06:20 PM
  How to test coil with igniter DJexor 2 10,709 03-22-2018 10:01 AM
Last Post: Project D
