Idle problems
03-30-2009, 01:43 PM
Post: #31
Idle problems
Maybe you could join the two small hoses together(temporary) and try to block the hole in aav if removed .That's what I did and it works .
The only problem is when it's cold , you 'll have to let your foot on the gas pedal to have idle , but it doesn't take long for the engine to be warm. Thanks again Jondee . Problem solved twice........ ; No more bouncing idle , due to your advice , and no more idle at all as I broke the engine again on my last rally event ...... It was a used one I bought while waiting the racing one to be rebuild !!Probably a broken piston or rings or both . Blue smoke and 1/2 liter oil for 20km ! My machinist is happy Regards Phil Filh Save the RWD cars |
04-01-2009, 04:03 AM
Post: #32
Idle problems
Picked up my gaskets and such at Toyota today to put the now RTV-free AAV back on the car. Cleaned everything, replaced vacuum hoses, burped the radiator, and ROCK SOLID 850 RPM warm idle without any other adjustments - 900 with the heater fan on max.
Looks like everything is good. The real test will be the drive to work in the morning as it's going to be below freezing. |
09-16-2010, 10:44 PM
Post: #33
Idle problems
waking up the post .
The idle problems are back on my car ! As written above, i removed the AAV and solved the unstable idle . But it's back again . Coolant level is ok and bled! Any idea where to look at? Phil Filh Save the RWD cars |
09-17-2010, 12:03 AM
Post: #34
Idle problems
Check for vacuum leaks.
Cheers... jondee86 |
09-21-2010, 10:57 PM
Post: #35
Idle problems
thanks , but last rally went bad , I first broke the exhaust , then, the starter,
followed by gearbox , and ended with smoking and underpower engine . A lot of work for next weeks . phil Filh Save the RWD cars |
12-23-2010, 10:18 AM
Post: #36
Idle problems
Has anybody tried to clean AAV or fix it somehow? Mine is keeping 400-500 rpm more during hot idle. Any tip for fixing & cleaning AAV?
12-24-2010, 09:33 AM
Post: #37
Idle problems
Yesterday I cleaned it with oven cleaner
[/img] Fun is not the straight line! |
12-25-2010, 08:05 PM
Post: #38
Idle problems
I opened it and there is moving cone (black) and plate with the hole. This picture is taken in boiled water so the cone almost close the hole for bypass air. The plate can be screwed in and out but I do not have such tool.
12-26-2010, 05:16 PM
Post: #39
Idle problems
So, after cleaning AAV and bleeding cooling system of air bubbles, I got 900 rpm warm idle
Not bed as there is -1 C outside. Of course, it could be better but as I don't have this adjusting tool 900 rpm is better then 1200-1300 as before. Cheers
12-26-2010, 05:27 PM
Post: #40
Idle problems
what is AAV... where to find it...
im having the same problem like you... high and unstable idle... what is and oven cleaner? some tip that u make this job a bit easyer? thanks alot |
| Blacktop 20V high idle | Bravothreezero | 2 | 221 |
08-10-2026 04:58 PM Last Post: ondafly |
| No idle below 2000 rpm rich running | Steller Engineering | 3 | 3,944 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 13,996 |
| Big wheel problems | gh0st | 16 | 15,082 |
| Starting problems 4-AGE kouki | Hanzo | 3 | 4,885 |
