I need people that know Electrics!!!
05-25-2011, 04:36 PM
Hi all,
After the brainstorm with my trunk - with ventilator holes in them - I want to take it further. It's just not enough... What I want to do now is either buy an A/C for the AE86 - BUT to be honoust - it's probably not gonna cool me very well... So I have been looking further and further and have come to the idea that I would like to buy a (omvormer) ... dont know how to call it but its a special block that makes 220V go to 12V (special electricity adaptor). What I want to try is plug in a relatively small CARAVAN aircon unit. Something like the Truma Saphir Compact or whatever. Or maybe a move-able little airco unit... as long as the thing can COOL! Any ideas of how I can achieve this or what might help? Please let me know guys... for me its really difficult. -DWG- Drift Wolf Gaming |
05-25-2011, 04:52 PM
Get A/C from some big limo, adapt it and put it on max. Stock AE86 a/c ain't that powerful even brand new.
05-25-2011, 05:01 PM
Uzelac Wrote:Get A/C from some big limo, adapt it and put it on max. Stock AE86 a/c ain't that powerful even brand new.Exactly that's what I am talking about... But how the F do I get a Limo A/C and what do you need to adapt? Is it difficult and how much would it cost you think? Thanks. -DWG- Drift Wolf Gaming |
05-26-2011, 08:22 AM
your best bet is to get a highduty aircon system like Toyota fits to the landCruisers/Hilux in Africa-Middle east. Problem is I'm not sure the can physicaly fit as the are huge in every aspect, evaporator, compressor, codensor etc... If I can find a cheap way to get a palett from UK to me I'll hav a n AC system that I can test in the harshest environment you can imagine but so far shipping quotes are more than just ridiculous.
AE86 ex-daily |
05-26-2011, 11:02 AM
Bean Bandit Wrote:your best bet is to get a highduty aircon system like Toyota fits to the landCruisers/Hilux in Africa-Middle east. Problem is I'm not sure the can physicaly fit as the are huge in every aspect, evaporator, compressor, codensor etc... If I can find a cheap way to get a palett from UK to me I'll hav a n AC system that I can test in the harshest environment you can imagine but so far shipping quotes are more than just ridiculous. Wow! Okay yeah I understand... I just need help for the summer or I will never get out the house ![]() -DWG- Drift Wolf Gaming |
05-26-2011, 11:10 AM
Well considering the temps here you have it good
![]() Anyway good luck and I will let you know if I make any progress on my side. AE86 ex-daily |
05-26-2011, 11:17 AM
Sorry, I just had to:
![]() Good luck with your plan. Retrofitting an AC is quite a task! http://monkeymagic86.wordpress.com |
05-26-2011, 06:50 PM
I hate you nomuken
05-28-2011, 09:47 AM
Okami Wrote:Something like the Truma Saphir Compact or whatever. Or maybe a The spec sheet indicates a current draw of 55 Amps @ 12 VDC. Assuming you can locate a 12 VDC=>230 VAC inverter with a suitable rating (say 800-1000 Watts, TRUMA have one), you could look at mounting a second dedicated 60A alternator in the position usually occupied by the A/C compressor. Probably need a battery in the circuit as well, to deal to the starting current. Then you could place the A/C unit in some kind of custom enclosure, maybe behind the rear seat (seatback folded down) with a sealing panel. The back end of the A/C needs to vented to atmosphere to get rid of the rejected heat. Some flexi-ducting and a little ingenuity should sort that out... and BINGO... you have A/C ![]() Cheers... jondee86 |
05-28-2011, 11:38 AM
Sick! Thanks for that!
Exhaust has white smoke coming out and I dont know why... | mister86 | 3 | 5,887 |
01-19-2020 12:06 AM Last Post: Power_uP |
What suspension set up are people using? | kazi | 8 | 9,777 |
07-06-2017 05:26 AM Last Post: headrush |
Anyone know what this plug does? | Super86 | 3 | 7,345 |
08-01-2016 03:57 PM Last Post: Nakilad |
Anyone know how to fix the digital clock? | kawo | 0 | 3,820 |
05-02-2014 08:54 AM Last Post: kawo |
All I should know about suspension before any modification | damusto | 20 | 24,954 |
05-24-2013 09:28 PM Last Post: damusto |
