I have question, disc brakes plus sr5?
09-15-2006, 07:49 AM
Is there a way to convert the drum brakes to disc...
well Im sure there is but I am in the dark, can somebody enlightin me?
09-15-2006, 11:48 AM
Hey evfan,
Yupz, a bit of work though. Not 100% sure but if I am not mistaken the disk brake assembly does fit onto a drum brake axle (allthough must people swap the entire axle since the drum brake axle doesn't fit the GTS LSD and it saves ALOT of work).
For the rest of the work I'm abit fuzzy but basically what you also need to do is install a hard brake line from the front to the back, and you need to alter some stuff on the master brake cylinder (I believe for drumbrakes they don't have one of those control valve thingies, so that bit needs to be swapped out). Also I believe the handbrake assembly is different so you will need to replace the cables.
Easiest is just to source the parts you need from a GTS and it should be a bolt on replace. Atleast thats what I've been told/have read. I've never actually done this Big Grin
09-17-2006, 04:01 AM
Alrighty thanks,
now with my search, a dead gts I can part from
  Rear brakes overheating Blaze0010 3 951 10-03-2025 05:57 PM
  Rear brakes totta Crolla 0 1,848 02-03-2023 12:54 PM
Last Post: totta Crolla
  Switching diffs for disc brakes? trippin 6 5,256 07-08-2022 03:35 AM
Last Post: trippin
  Rebuild rear disc brakes toyota crown ms112 axle bozu 0 4,831 12-21-2016 09:37 PM
Last Post: bozu
  How would/have you rebuild your 4age? joaotcgt 6 11,034 07-21-2015 10:40 AM
