How to save a cover rubber of gearbox shift ???
02-26-2011, 11:15 AM
Hi, i searched in the forum but i didn't find it.
I put on a T3 quick shift, and all was Ok, but the problem is that Toyota hasn't for sale the cover rubber of gearbox shift (not the boot), And i can't find a way to remove the rubber of the original shift, because below has the "rolling ball" with biggest lever balls and above a thick tube Anyone know how to extract it? This is the rubber: ![]() Rolling ball below: ![]() Thick tube above: ![]() Thanks. Regards ![]()
02-26-2011, 02:08 PM
You can only try to pull it over the "thick tube above" using dishwasher liquid, there is a 50% chance it breaks cause of age
![]() But its not that bad if it breaks, the smaller boot beneath it is much more important, cause it keeps moist and dirt away from entering the gearbox! The´re impossible to get of and always break. I suggest this: http://cgi.ebay.de/ws/eBayISAPI.dll?View...0631726166 It fit´s Toyota K50/K40 boxes and should fit T50, too (same dimensions). If you find something cheaper let me (us) know! :wink:
02-26-2011, 06:04 PM
if you dont care about your original shifter, heat the thick tube, it's only glued
02-26-2011, 11:00 PM
fax0815 Wrote:The´re impossible to get of and always break. It's not bad idea, it protects the rollin ball, but i'm looking for something to separate the interior pieces of the under outside, like you said, is so easy to break the rubber. So the boot is still available, part reference: 33555-12090 ![]() Boot on the T3 (i assured with a band flange) ![]() Project D, i'll try it, i think i'll not reassemble the original Thanks ![]()
02-26-2011, 11:03 PM
you can use one form a nissan 200sx s13 or s14, they are a little bit larger but still available and will do the trick.
02-26-2011, 11:07 PM
eBay...
http://cgi.ebay.com/TOYOTA-COROLLA-KE70-...483f12db8e http://cgi.ebay.com/ebaymotors/1989-95-t...ccessories http://cgi.ebay.com/ebaymotors/COROLLA-K...ccessories http://cgi.ebay.com/ebaymotors/TOYOTA-CO...ccessories http://cgi.ebay.com/ebaymotors/TOYOTA-TE...ccessories "Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!" ""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff" -Henri Toivonen 2.5.1986- http://www.youtube.com/watch?v=OwgB4Xs4LVQ |
02-26-2011, 11:46 PM
T_AE86 Wrote:fax0815 Wrote:The´re impossible to get of and always break. Ok, but how much did it cost you from Toyota? 1979 Toyota Corolla KE35 1983 Toyota Corolla AE86 1985 Toyota Corolla AE86 |
02-27-2011, 12:52 AM
Thanks, if i can't save it, that's the only solution
fax0815 Wrote:Ok, but how much did it cost you from Toyota? It cost 8.41€ ![]()
| car cover | kawo | 3 | 5,664 |
07-24-2013 09:09 AM Last Post: totta Crolla |
| Broken 20v upper timing belt cover | chip | 2 | 5,114 |
07-16-2012 07:11 AM Last Post: Jan Pedersen |
| Interesting 20v cam cover mod | banpei | 3 | 9,996 |
05-31-2012 02:44 PM Last Post: Kid Karola |
| Rubber sealing on oem sideskirts | Jimmi The Kid | 4 | 7,619 |
06-22-2011 09:16 PM Last Post: Jimmi The Kid |
| Front wheel bearing cover : Partnumber | danworth | 5 | 6,999 |
11-14-2009 01:09 PM Last Post: danworth |
![AEU86 AE86 - How to save a cover rubber ... shift ??? [Image: AEU86 AE86 - How to save a cover rubber ... shift ???]](http://i142.photobucket.com/albums/r120/tomiRS/26022011226.jpg)
![AEU86 AE86 - How to save a cover rubber ... shift ??? [Image: AEU86 AE86 - How to save a cover rubber ... shift ???]](http://i142.photobucket.com/albums/r120/tomiRS/26022011227.jpg)
![AEU86 AE86 - How to save a cover rubber ... shift ??? [Image: AEU86 AE86 - How to save a cover rubber ... shift ???]](http://i142.photobucket.com/albums/r120/tomiRS/26022011228.jpg)
![AEU86 AE86 - How to save a cover rubber ... shift ??? [Image: AEU86 AE86 - How to save a cover rubber ... shift ???]](https://st.forocoches.com/foro/images/smilies/r.gif)
![AEU86 AE86 - How to save a cover rubber ... shift ??? [Image: AEU86 AE86 - How to save a cover rubber ... shift ???]](http://i142.photobucket.com/albums/r120/tomiRS/26022011229.jpg)
![AEU86 AE86 - How to save a cover rubber ... shift ??? [Image: AEU86 AE86 - How to save a cover rubber ... shift ???]](http://i142.photobucket.com/albums/r120/tomiRS/26022011233.jpg)
