How to safely remove front and rear bumper.
04-12-2006, 02:48 PM
hi guy's i wanna know how to safe remove bumpers on rusty hachi because i was one time having bad experience that i destroyed the plastic mountings on rear bumper when i tired to remove the bumper after the fight with rusty screws. I dont try that again with that hard method and wanna also know what screws to remove... can someone tell me how to do it and also how to safely remove the screws is they are rusty ? Pics will help too! Thanks.
85' AE86 GT coupe lifetime project since 2005 |
04-12-2006, 03:06 PM
Hey Ryo,
For the rear you need to loosed the 4 big bolts on the bottom of your boot they are metal on metal so I doubt you'll damage any plastic there. Then there are only 2 small screws on the inside on the side, and 2 small screws where the bumper meets the wheel arches. Not sure about the front bumper but last time I loosened it I didn't have any problems but I loosed them directly on the bumpers. In the end, best thing to do is soak them a couple of times in WD40 and then loosen them. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-12-2006, 03:57 PM
The front bumper is fixed with 2 very big bolts to the frame on each side...the bolts on those bumper mounts are usually a bitch to get loose...so use wd40 copiously, use good tools and hope you dont break anything. I just removed the bolts from the mount to the bumper itself, but you have some bad experiences with that from what I can gather.
04-12-2006, 04:44 PM
Thanks for the explanation guy's i let you know if i was have been sucesfull.
Have the WD40 ready :wink: . 85' AE86 GT coupe lifetime project since 2005 |
04-12-2006, 05:11 PM
Don't forget there are also two on the bottom of the rear-bumper.
04-12-2006, 05:24 PM
well i dont need to remove one of those... because one was gone with that rusty piece of metal
04-12-2006, 05:35 PM
Ryo Wrote:well i dont need to remove one of those... because one was gone with that rusty piece of metalAh, you meant those screws gave you a good fight... One of mine (on the side which actually needs it badly!) is still in there, so I know what pain they are. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
| Passenger roof grab handle - how to remove ? | ondafly | 3 | 1,186 |
02-19-2026 07:20 PM Last Post: ondafly |
| Can you seperate trueno kouki bumper lights into zenki bumper lights? | gh0st | 17 | 15,372 |
| S13 Front brakes in AE86 rear | heshan | 25 | 36,041 |
02-01-2014 12:37 PM Last Post: heshan |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 8,311 |
| Zenki trueno indicatop and zenki levin bumper MR2 aw11 | BOOMEX | 3 | 8,066 |
12-28-2011 12:16 PM Last Post: BOOMEX |
![AEU86 AE86 - How to safely remove front ...ar bumper. [Image: AEU86 AE86 - How to safely remove front ...ar bumper.]](https://www.aeu86.org/sticker-banner-468.gif)
