How to install seat harness
02-05-2007, 05:41 PM
Where do I mount studs for harnesses that go beside the seat?
02-05-2007, 06:48 PM
you already have two threaded holes from the original seat harnes... Wink One on the right on the reef and the other one on the B post (column)... You just need those ankers... O-ringed thingys to screw in there... You can buy them in Lučko... Wink going on stara Karlovachka after the school on the left... all sort of metal stuff Wink
SNO-MO-BIRU project started- CHIRO
02-05-2007, 06:51 PM
Thnx mrgud, you have pm (regarding struts&sole)
02-05-2007, 07:23 PM
Under rear seat you have bolts for stock rear seat harness...
Even better is rear strut bar, if you have one.
Pic that better explaines...
Toyota scrap yard car park = AE92GTi - AE82GT - KE30 - KP62
02-05-2007, 08:03 PM
meshin Wrote:Under rear seat you have bolts for stock rear seat harness...
strut bar is ideal... This is too much harnes angle Mesh... You are risking with this... check Appendix J FIA... you will see why... Althou this is better than the ones I saw on some cars... Wink
02-05-2007, 08:48 PM
How would you go about it without having to rip out your rear seats?
[Image: AEU86 AE86 - How to install seat harness]
02-06-2007, 01:35 PM
2 mrgud: this is the best I can do in my car for now. Waiting rear strut bar, then it would be on it.
2 TRUENO><ONEURT: my friend screwed the harness like this on picture, but put something like holder (screwed in) little higher so the harness was going right between the crack in rear seats (between horizontal and vertical joint of the rear seat, if you know what I mean).
02-06-2007, 03:59 PM
Get a harness bar. It's the best way to mount them.
Peter Diaz
http://www.shiftgearclothing.com
http://www.ectoyotas.com/forum/
http://www.facebook.com/elfatherae86
02-06-2007, 08:03 PM
tomstwincam Wrote:Get a harness bar. It's the best way to mount them.
+1 I've never been to confident running the harness down to the rear seat belt anchor points. They're just too low for my peace of mind. Also most rear strut tower bars are not designed with harness attachment in mind. I've been staying away from harnesses until I can have a harness bar built or possibly even a cage.
02-06-2007, 10:45 PM
Can't you mount them right behind the front seat?
Id need the rear seats for transport of friends
  Bucket seat prices gh0st 5 5,245 01-23-2022 11:44 PM
Last Post: AlexKTM
  AE86 4A-GE 16v engine harness rebuild FanIsHere 7 15,472 01-17-2020 08:04 PM
Last Post: Project D
  Rear Seat Belt Question sleepercivic 5 12,808 06-29-2017 09:30 PM
  CD player install. kazi 8 12,964 02-21-2017 11:57 AM
  Foam-ectomy on OEM Seat mad.matt 2 6,048 02-17-2017 12:22 AM
