How to: Replace disc brake and pads on rear axle
07-04-2005, 08:48 PM
Step 5: take the brake pads out of the brackets, then loosen the two bolts holding the bracket to the axle. The bracket will come off nicely.
Step 6: Take the brake disk off. If it is stuck there are two small holes in the brake disk in to which you can screw a bolt, this bolt will push the disk off. Make sure you put a bolt in both holes and tighten them evenly or the disk will get stuck even more. IF it still doesn't come loose, a hamer does wonders ![]() Step 7: Put the new disk on. For those with a keen eye you will notice we forgot to push the disk in place enough, we eventually had to loosen everything again, put the disk on right, and put everything back on again So lesson to be learned, put the new disk brake firmly in place.Also brake cleaner is very important at this point. The disk brake will be covered in yucky stuff to keep it from rusting, spray on brake cleaner on the brake surface and wipe it off with a clean rag to remove this yucky stuff. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
| Messages In This Thread |
How to: Replace disc brake and pads on rear axle - Mux213 - 07-04-2005, 08:40 PM
[] - Mux213 - 07-04-2005 08:48 PM
| AE86 rear axle weight | megabob | 11 | 22,830 |
| Axle width | totta Crolla | 1 | 2,396 |
| PWR light issue and no brake fluid after winter storage | magpie | 10 | 5,966 |
| Switching diffs for disc brakes? | trippin | 6 | 5,091 |
07-08-2022 03:35 AM Last Post: trippin |
| How to replace the steering column UJ? | Mylesmck | 4 | 3,919 |
05-14-2022 07:40 PM Last Post: Ivan141 |
