How the 4A-GE ECU works
03-04-2007, 12:22 AM
Post: #71
Sorry, too lazy to read all post, but isn't just built in processor in stock ECU.
Very easy to built in megasquirt processor in ECU...
Best regards Finn
03-09-2007, 01:50 AM
Post: #72
JMR: Am i right ?.
Finn
03-09-2007, 08:43 PM
Post: #73
Toyota T23 Wrote:JMR: Am i right ?.
Finn
About the ECU MCU or the Megasquirt? Smile
The stock ECU uses a MCU with built in mask programmed ROM. To make it tuneable requires additional hardware that runs the stock ROM in external memory.
I don't know enough about the MS to answer your second point.
03-10-2007, 01:35 AM
Post: #74
Thought so..
Thanks
Finn
03-11-2007, 03:48 AM
Post: #75
"Isn't the W terminal supposed to light up the LED on the cluster, the Check Engine Light itself?"
LED ON THE CLUSTER??? I don't know what they shipped to the EU, but in 1985/6/7, I don't think Toyota shipped a single LED in any part of any one of the AE8x cars in the US.
Them's 12-volt incandescent LIGHT BULBS in the instrument cluster, just like every other illuminated object in the car. (Except the blue dashboard clock.<G&gtWink
Original owner, 1985 Toyota Corolla GT-S in the US of A. Will trade for a Cadillac-Gage V150 or a Ford GT44.
03-26-2007, 01:43 PM
Post: #76
i have a ECU AW11 i want to know what chip or model or type of eprom have the ecu installed and what chip or eprom on the ecu have the configuration, map or setup for reprogrammer?
What Type of Eprom programmer i have to buy ? Tnks
03-27-2007, 07:48 AM
Post: #77
Yeah, Red, you're probably right, but for the purposes of the experiment it didn't really make a difference what the lighsource was specifically. In case people need info - it worked with the battery positive, through a 1kO resistor and a LED, attached with cathode to W.
07-26-2007, 03:41 PM
Post: #78
+subscribes
07-27-2008, 07:46 PM
Post: #79
Hy
its possible to get the informations again.
the links from the year 2006 didnt work any more.
thx for your help.
Br, stefan
07-27-2008, 10:56 PM
Post: #80
Unfortunately not: I did find later parts (part 5 and 6 I thought) but these parts have disappeared. Crying
I did even try http://www.archive.org but no success and besides that: you will miss the images then. Sad
[Image: AEU86 AE86 - How the 4A-GE ECU works]
  Would a yamaha tachometer works?? andrecorreia 1 4,153 07-21-2008 01:38 PM
Last Post: andrecorreia
  Wich ecu standalone works better in a 4AGE Abe 18 33,912 02-17-2007 12:54 PM
Last Post: PazzaAE86
  Not understanding LSD - how LSD works surfingdrums 11 20,226 09-13-2006 11:58 AM
Last Post: Mux213
  Fuel gauge: works but shows lower than real?? PetzK 18 21,206 10-23-2005 11:37 AM
