Horn assembly
08-10-2018, 12:33 PM
Horn assembly
Hi folks,
I have to change my horn to stock (previously had a air horn). There are 4 connectors so I assume the car usually has 2 horns (low and high pitch) right? I have the part numbers. Has anyone a photo on how to mount these? Hard to find pictures of that part of the engine bay. Thanks. |
08-10-2018, 04:20 PM
Horn assembly
If I remember correctly they are mounted with 1 bolt to each of the uprights between the radiator and bumper (with the horns pointing towards the center)
Sent from my MHA-L29 using Tapatalk AE86 ex-daily |
08-10-2018, 06:50 PM
(This post was last modified: 08-11-2018 10:28 AM by Hama86.)
Horn assembly
I made this photo earlier today. Their is one bolt hole and one with a bolt already in. You mean those places? And they face sideways toward the center line of the car?
Just to clarify, the horns are diaphragm or snail type? |
08-11-2018, 01:27 AM
Horn assembly
Pictures aren't working for me.
08-11-2018, 10:28 AM
| Horn assembly | |||
08-11-2018, 07:06 PM
Horn assembly
They are diaphragm types and one goes where you have the bolt hole, not sure on the swcond one as my previous owner fitted airhorns too and I just installed a small hidden switch to change between them.
| Horn mounting... | Mylesmck | 6 | 3,818 |
07-12-2023 10:03 AM Last Post: Mylesmck |
| Air Cleaner Assembly | Hama86 | 7 | 11,671 |
10-29-2018 03:28 AM Last Post: Hama86 |
| Engine block assembly | drako323 | 10 | 15,407 |
05-19-2011 07:38 PM Last Post: fax0815 |
| What wires are the horn ones ? | franckcrx | 4 | 6,531 |
02-15-2009 09:08 PM Last Post: franckcrx |
| Horn wire | Rasteirinho | 1 | 4,184 |
09-20-2007 12:37 AM Last Post: Rasteirinho |
