High oil pressure
10-13-2005, 12:25 PM
High oil pressure
can somebody tell me more what to do with high oil pressure.
[Image: AEU86 AE86 - High oil pressure]
10-13-2005, 12:34 PM
High oil pressure
New piston rings maybe?
[Image: AEU86 AE86 - High oil pressure]RX-8[Image: AEU86 AE86 - High oil pressure] -- AE86 --
10-13-2005, 01:03 PM
High oil pressure
The by-pass valve in the oil pump is mayby stock.....
I still play with cars......
10-13-2005, 01:10 PM
High oil pressure
First tell us how high the oil pressure is at the moment (on the scale).
My last engine had broken 2 piston rings and the oil pressure was very high back then. Easiest way to check that is to pull the crankcase ventilation tube from the inlet manifold and see how much smoke is coming out..big clouds/oil coming out of the air filter indicate a dead engine. Also: does it idle normally? My old broken engine couldnt keep running at idle anymore when it was warmed up.
10-13-2005, 01:27 PM
High oil pressure
High oil pressure it’s not a bad thing at all. I don’t know why you are so worried about it.
How much high is it on the scale?
Fun is not the straight line!
10-13-2005, 01:39 PM
High oil pressure
I'm a bit more worried about my low oil pressure at idle these days..it's at the half of the scale (lowest line in safe area), and drops even a bit under that when the engine idles lower than 900rpm.
On the other hand unusually high oil pressure can be an indicator that there is a lot of blow-by past the pistons.
10-13-2005, 02:31 PM
High oil pressure
Ivan141 Wrote:I'm a bit more worried about my low oil pressure at idle these days..it's at the half of the scale (lowest line in safe area), and drops even a bit under that when the engine idles lower than 900rpm.
Same here!
During driving it stays around 70-80% of scale and during idle it drops a little bit under minimum line.
I’m using Valvoline full synt. 5w-40. It was the same with Castrol RS 10w-60.
10-13-2005, 03:11 PM
High oil pressure
I almost don't drive it above 3k RPM because of the pressure.
10-13-2005, 03:16 PM
High oil pressure
i shouldn't be to worried if i were you.
That's the region it should be in!
Your instruction book (if you got one ...) states that this is the perfect value for a warm 4A-GE.
And if the pressure is really to high, it's gonna drop down automaticly someday Big Grin
10-13-2005, 03:42 PM
High oil pressure
The Doctor Wrote:And if the pressure is really to high, it's gonna drop down automaticly someday Big Grin
LOL!
Thanks for the info guys! Thumbs up!
  Blacktop 20V high idle Bravothreezero 2 323 08-10-2026 04:58 PM
Last Post: ondafly
  High-beam warning lamp Mylesmck 4 4,393 07-21-2023 07:44 AM
  Engine stress at high speeds gh0st 6 5,925 08-30-2022 07:11 PM
Last Post: Power_uP
  4AGE 16V engine overheat when at high speed chenfon 32 37,807 12-31-2020 06:39 AM
Last Post: chenfon
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 26,316 08-19-2018 12:08 PM
Last Post: AlexKTM
