High engine oil temps - oil cooler discussion
06-04-2008, 07:56 AM
4agze Wrote:FC3S oil cooler 5 years now and 2 motors ago still running strong keeps my oil 90C to 100C all day 9,200rpm. people dont know that FC3S oil cooler has a build in thermostat.
[Image: AEU86 AE86 - High engine oil temps - oil...discussion]
Does all FC3S coolers have a thermostat? If so I'm going to get me one Thumbs up!
06-04-2008, 08:54 AM
SutteR Wrote:As far as I know there is a pressure operated valve in stock. If you use the stock lines with the FC3S oil cooler won't it operate only on high revs because of this pressure valve?
Question is if it can be avooided to run the oil through this pressure valve.
you can remove the valve if you want, when i go to the track i just remove the thermostat
Quote:Does all FC3S coolers have a thermostat? If so I'm going to get me one
as far as i know they all do even the japanes RX7 FC3S are all same
06-04-2008, 09:15 AM
4agze Wrote:
SutteR Wrote:This sounds interesting. Did you simply connected the pipes to the engine block like it's in stock?
yes, just remember to put it upside down, the thermostat plug facing up so you can unscrew the plug and drain it every oil change.
sorry need to correct myself the thermostat plug facing up NOT down im sorry.
here is another pic of it from my friends car
06-05-2008, 11:14 AM
Bought this yesterday:
More pics here: http://picasaweb.google.com/czutorgergel...FC3SOlajhT
Now I need to find a 'free-flow' sandwich plate which suits the hachi engine and make some hoses to connect them. Would be great to be able to use the FC oil lines more or less...
1987 Toyota Corolla GT coupe - for holidays oversteer
2005 Toyota Corolla - for daily understeer
06-05-2008, 12:48 PM
Nice SutteR! Let us know wich sandwich plate you go with...
Btw how much did the cooler cost?
06-05-2008, 12:53 PM
Jan Pedersen Wrote:Nice SutteR! Let us know wich sandwich plate you go with...
I tell you but you won't believe it for sure. Smile It was ~40€ total with the thermostat in and the hoses. Only little bents on the radiator, otherwise great shape.
Adapter will be no problem, I just look for the cheapest but still reliable option.
Hoses with fittings will cost more than the adapter and the cooler I suppose.
Will keep you informed.
06-05-2008, 12:58 PM
Thats cheap! I found one for €100 but we don't have that many RX7s in Denmark, so they don't lay around much Smile
06-08-2008, 11:23 PM
For all you Euro guys wanting to go for the mega overkill RX7 cooler route ... here's one for sale.
http://retrorides.proboards86.com/index....read=41481
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
  High-beam warning lamp Mylesmck 4 3,500 07-21-2023 07:44 AM
  Mocal oil cooler & sandwitch plate ordered Gtsi-R 48 67,651 11-18-2022 02:19 PM
Last Post: FanIsHere
  Engine stress at high speeds gh0st 6 4,947 08-30-2022 07:11 PM
Last Post: Power_uP
  Oil cooler totta Crolla 0 2,509 07-25-2021 03:25 PM
Last Post: totta Crolla
  4AGE 16V engine overheat when at high speed chenfon 32 33,482 12-31-2020 06:39 AM
Last Post: chenfon
