Help with rear differential size
07-11-2007, 05:27 PM
Hi all. I´m working on a 84 levin that originaly had a 3.90 rear differential with no LSD and drum brakes, so as you can imagine I need to change my entire rear axle. I have two options right now but I have some doubts that I hope you can help me with.
7.5 inch rear diff with LSD and 4.37 final ratio with disc brakes (i think is from a nissan pickup, already modified to fit in the ae86). 6.7 inch rear diff with LSD and 4.11 final ratio with drum discs (from a 82 or so corolla). Of course I would have to fit in disc brakes later if I choose this one My biggest concern is about the size of the differential, I don´t want to lose power if I choose the 7.5 inch diff. Have any of you adapted a big differential like this one? did you lose any power? by the way, my engine is a 20 valve 4ag (silver top) thanks! |
07-11-2007, 06:37 PM
You might loose a bit on power, but you gain reliability.. you can do a lot to that 7.5" rearend without it even breaking a sweat..partwise the toyota rear axle is a lot more expensive to maintain too (compared to puckup truck rear axles).
07-11-2007, 06:44 PM
Thanks, I totally agree with the reliability part, but would I feel that "little bit" of power loss? I mean if its 3 hp I don´t care but I don´t want to have 10 or 15 less hp because of that differential
07-11-2007, 06:56 PM
Cant help you there..no experience with it. I dont see why it would rob that much power.. the frictional losses cant be that much bigger than on the 6.7, so it's probablythe weight that's going to count.
07-11-2007, 07:37 PM
ok, thanks a lot anyway!
Does anyone have an idea of how much % would the power loss be? With the 7.5" differential? |
07-12-2007, 10:40 AM
The power loss is no concern here, don't worry about difference between 6.7 and 7.5. Get 7.5 IMHO.
07-12-2007, 03:43 PM
7.5 it is then
thanks a lot for your help! |
| Differential specs | MatuOjav | 2 | 1,233 |
12-03-2025 07:06 PM Last Post: MatuOjav |
| Rear Differential rebuild | chenfon | 10 | 15,156 |
11-20-2020 12:18 AM Last Post: totta Crolla |
| Shim size for AM cams | kazi | 4 | 7,739 |
| Hub size | kazi | 5 | 12,482 |
| Camshaft sprocket bolt size? | harkes | 1 | 6,276 |
