Help with brakes needed! FIXED
08-21-2009, 03:11 PM
Hello everyone!
Brakes are now ok. They didn't work because of my wheel bearing had broken really badly. I changed new bearings and brakes are back! |
08-21-2009, 04:50 PM
Internal leak in the master brake cylinder could cause such a thing..
look for bubbles in the fluid reservoir (have someone press the brakes a few times). Bubbles = not OK. FABRICA MI DIEM, PVNC! |
08-21-2009, 06:46 PM
Ivan141 Wrote:Internal leak in the master brake cylinder could cause such a thing.. +1 :wink: SR Team BURN THE RUBER NOT YOUR SOUL! |
08-21-2009, 07:09 PM
Thank you for your replies. We checked that... No bubbles. Any other ideas?
08-21-2009, 10:18 PM
Boiled fluid probably. Bleed through new fluid, 1 litre should be enough.
Did you bed in the new pads ? An analogue brain in a digital World |
08-23-2009, 07:24 PM
Brakefluid seemed very old when me and my friend bled the brakes. No air was in the brakesystem, but we noticed that left front and right back corner didn't have much pressure. Brakefluid just like dribbled from the bleedscrew.
08-23-2009, 09:57 PM
I'm not sure how the standard brake limiter valve works on the '86 but generally if you bleed the rear brakes with the rear wheels in the air, ''hanging'', the line pressure will be limited.
08-23-2009, 10:02 PM
totta Crolla Wrote:I'm not sure how the standard brake limiter valve works on the '86 but generally if you bleed the rear brakes with the rear wheels in the air, ''hanging'' the line pressure will be limited. We did both sides separatly. So only one wheel was up everytime.. |
08-23-2009, 10:30 PM
After the pedal went to the floor did it pump back up again ?
It it did was it a good pedal when cold ? The system is split front to rear, have you tested that both systems work ? An analogue brain in a digital World |
08-23-2009, 10:35 PM
totta Crolla Wrote:After the pedal went to the floor did it pump back up again ?Yeah the pedal pumps back up. What do you mean by testing both systems? |
| Rear brakes overheating | Blaze0010 | 3 | 2,034 |
10-03-2025 05:57 PM Last Post: banpei |
| Rear brakes | totta Crolla | 0 | 2,410 |
02-03-2023 12:54 PM Last Post: totta Crolla |
| Switching diffs for disc brakes? | trippin | 6 | 6,762 |
07-08-2022 03:35 AM Last Post: trippin |
| Help needed | totta Crolla | 3 | 6,258 |
05-15-2020 10:07 AM Last Post: totta Crolla |
| Some wiring help needed | DJexor | 5 | 8,783 |
