Help on Tyre selection - asap - PLEASE!
01-24-2011, 09:20 PM
Hello,
I have original 14 inch rims with tire size : 195/60/R14 I want to get my 13 inchs rims fitted... 13 x 7.0J ET-7 Wat tires/tire size should I use to keep it close to the OEM distance... 165? to pull the tires and make the rims pop out a bit more? 165/60/13? I have noooo clue whatsoever about tires and all that... Sorry. Please help! Thanks!!! This is the problem now ![]()
-DWG- Drift Wolf Gaming |
01-24-2011, 09:31 PM
165/75R13 would match OEM size, but it's probably easier to check what sizes are available at all in 13" and then plug the numbers in here http://www.carbibles.com/tyre_bible_pg4.html does all the math for you
AE86 ex-daily |
01-24-2011, 09:42 PM
Thanks!
I just came across this link also http://www.buggyboys.be/nl/tech_tellerafwijking.htm And found out if I would choose this tire-size : 175/70/13 The height would then be 1 cm smaller and -5cm with the wheel running So it would almost be the same with OEM but the wheels would spin faster vs the OEM size. -DWG- Drift Wolf Gaming |
01-24-2011, 10:26 PM
185/60/13
Probably the best selection of tyres in this size. Plenty of used race tyre bargains available for drifting in 13" too :wink: Don't lower the front of the car too much in relation to the back. An analogue brain in a digital World |
01-24-2011, 10:38 PM
totta Crolla Wrote:185/60/13 Thanks... the lowering in front was due to the OEM size wheels... I did not know it was going to be THIS AWFULL with the new rims and tyres hahaha I apologize for the nose-diving-look -DWG- Drift Wolf Gaming |
01-24-2011, 11:16 PM
totta Crolla Wrote:185/60/13That's the default size for the pizzacutter rims. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
01-30-2011, 11:18 AM
totta Crolla Wrote:185/60/13 Probably the best selection of tyres in this size. Agreed. I used 185/60-13 slightly stretched onto that exact same wheel. ![]() Cheers... jondee86 |
01-30-2011, 01:52 PM
Thanks again everybody... Yesterday I allready picked up the rims+tires
01-30-2011, 07:15 PM
Nice looking '86 there Jondee
Can you please tell me the rim width and the offset of those wheels... An analogue brain in a digital World |
01-30-2011, 09:34 PM
Looking good!
| Tyre load index | Blaze0010 | 6 | 3,414 |
06-12-2025 04:59 PM Last Post: Blaze0010 |
| TUV RHD AE86 Germany (help please) | 4dori | 9 | 10,978 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
| Carb question please help | MIGGZFSU | 3 | 6,722 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
| Whining noise HELP PLEASE | izanagi | 10 | 16,603 |
03-26-2015 06:48 PM Last Post: Komba |
| the connector saga (please help everyone) | Bean | 8 | 12,456 |
06-23-2014 01:13 PM Last Post: Bean |
![AEU86 AE86 - Help on Tyre selection - asap - PLEASE! [Image: AEU86 AE86 - Help on Tyre selection - asap - PLEASE!]](https://www.aeu86.org/sticker-banner-468.gif)
![AEU86 AE86 - Help on Tyre selection - asap - PLEASE! [Image: AEU86 AE86 - Help on Tyre selection - asap - PLEASE!]](http://homepages.paradise.net.nz/~wjd/84ae86gt.jpg)
