Help! Car won't start, but gets fuel.
09-04-2008, 03:15 AM
If you're getting no fuel and no spark, it's most probably the ECU that's at fault. The fuel pump grounds out without the aid of the ECU, so going through the fuel rail is normal, even if the ECU is not sending out a signal.
Also your crank/starter motor is seperate entirely from the ECU so that will work fine also. Do you hear your ECU click when you turn on the ignition? if not, then check the fuses and relays that lead to it. As for the 3 wires in two injectors? that sounds a bit off if you ask me, you may want to get another injector connector and sort out the wiring there. |
| Messages In This Thread |
Help! Car won't start, but gets fuel. - generalachoo - 08-17-2008, 11:41 PM
[] - Rasteirinho - 08-20-2008, 12:20 PM
[] - Jezza_hr - 09-04-2008 03:15 AM
| Refreshed 20v blacktop first start.. | Mylesmck | 6 | 3,967 |
| Warm start problem | DJexor | 5 | 5,398 |
| Engine starts/revs but no idle | GenkiMotors | 17 | 14,765 |
11-20-2021 04:12 AM Last Post: GenkiMotors |
| Weak spark, doesn’t start. | AlexFourTwenty | 4 | 19,012 |
| Won´t start | AlexKTM | 6 | 21,075 |
12-04-2017 10:05 PM Last Post: banpei |
