Header + exhaust for Beams setup
09-27-2011, 03:22 PM
Any advise?
Looking for a 4-2-1 + mid pipe + exhaust to fit to the beams.
I believe there should be no off the shelf item and need to go for custom.
But at least I need the advise for the 4-2-1 header and I think I can manage to get the mid pipe and exhaust custom made.
Please share your idea.
Thanks,
Yung
09-27-2011, 09:29 PM
How large an exhaust diameter do you need? I assume this is for an AE86?? I know of 2 full size muffler exhausts(over axle) that use 60mm diameter piping. One is Kakimoto R - http://www.kakimotoracing.co.jp/image_ts332.html Cost: about 75000 yen
[Image: AEU86 AE86 - Header + exhaust for Beams setup]
The other would be Brave - http://www5f.biglobe.ne.jp/~brave-nh/pro...-list.html - look for BRMT028 Cost: about 39800 yen
Dan -
09-28-2011, 02:57 AM
It is for my 86 and currently installing a Beams on it, so need a different exhaust.
I would like to go for a standard dia now, not sure if the standard one for Beams is 60mm?
I have the stock header now but apparently it is too low and nearily touch the ground.
Wondering should I go for a after makert 4-2-1 header or just modify the stock one to fit a custom make down pipe then so on.
09-29-2011, 03:45 PM
So, does anyone know if the stock exhaust for beam is 60mm dia?
Thanks in advance.
10-02-2011, 06:59 AM
According to this, it appears to be 60mm.
http://trdparts.jp/english/parts_engine-3s-ge.html
Andrew
10-02-2011, 06:15 PM
Thanks Andrew!
I think I will go for a 86 - 60mm mid to exhaust and modify the header to fit it.
I believe you do the same in your car, right?
Cheers! Thumbs up!
10-02-2011, 07:42 PM
KD2229 Wrote:Thanks Andrew!
Cheers! Thumbs up!
I'm running the Brave in my car... :wink: http://s79.photobucket.com/albums/j143/o...peview.mp4
Dan -
10-03-2011, 07:25 AM
Dan,
You've got PM.
  4 Link setup and Traction brackets Jezza_hr 5 13,870 07-21-2014 09:12 PM
  Toyota KE70 3SGE Beams Swap - Axle reliability cke70 15 36,042 04-13-2014 12:49 PM
Last Post: Celica RA45
  Wanted: Link to Beams Blacktop engine manual pdf irishtwincam 7 15,340 01-03-2014 11:31 AM
Last Post: irishtwincam
  20v 4age header Alex170984 5 10,219 10-30-2013 12:53 AM
Last Post: fax0815
  DIV 1 rally/track suspension setup ditn 60 97,537 03-28-2013 11:28 PM
Last Post: ditn
