Gt86 diff in an ae86
05-14-2022, 04:33 PM
Hey everyone,
I have a question regarding diffs. Can a stock gt86 differential fit in an ae86? Also is a stock zenki differential better than a kouki differential? Or are they literally the same? Thanks! |
05-14-2022, 04:51 PM
No, and no.
The GT86 has an 8 inch diff (compared to the 86's 6.7 inch). Big size difference there. The differentials are more or less the same. Kouki uses bigger shafts so the hole in the gears might be different but nothing worth mentioning. The bigger shafts are a plus though. FABRICA MI DIEM, PVNC! |
05-19-2022, 04:21 PM
(05-14-2022 04:51 PM)Ivan141 Wrote: No, and no. Thanks, that clears things up. I have another two questions. 1. Can you put a zenki lsd in a kouki ae86? 2. Does a factory ae86 lsd have a 2 way setting? |
05-19-2022, 04:56 PM
(05-19-2022 04:21 PM)gh0st Wrote: I have another two questions.No and No. To fit a zenki LSD in a kouki AE86, like Ivan said, you need different size the halfshafts as well. You can find the pictures of both sizes here: http://www.aeu86.org/2014/09/25/ae86-the...-approach/ OEM diff is 1.5 way and you can swap it for an aftermarket 2 way. 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
05-19-2022, 06:03 PM
(05-19-2022 04:56 PM)banpei Wrote:(05-19-2022 04:21 PM)gh0st Wrote: I have another two questions.No and No. Thanks, that’s very helpful ![]() What 2-way lsd would you recommend me? |
05-20-2022, 11:13 AM
why would you like to go for a 2 way instead of a 1,5 way?
05-20-2022, 11:29 AM
Most importantly, for what purpose are you building the car? Street, track, grip, drift... all important to know when choosing a new lsd.
ハチロク
05-20-2022, 01:45 PM
(This post was last modified: 05-20-2022 01:46 PM by gh0st.)
(05-20-2022 11:13 AM)r.ave Wrote: why would you like to go for a 2 way instead of a 1,5 way? 2 way is for drift, 1,5 is for grip. I want drift! (05-20-2022 11:29 AM)zenki Wrote: Most importantly, for what purpose are you building the car? Street, track, grip, drift... all important to know when choosing a new lsd. Street, drift. But i’d also like to use it for recreational track use |
05-20-2022, 02:32 PM
Cusco has the MZ line where you can change the behaviour. I haven't checked if the make one for the Corolla but I guess they do. That's obviously just one of the many options but probably one of the more versatile ones.
AE86 ex-daily |
05-20-2022, 04:38 PM
With the Cusco RS line you can also do that. Mine is currently setup as 1.5 but you can easily change it to 2 way.
@Ghost, The oem lsd is 1.5 and plenty of people have drifted with that. ハチロク
| Using a different diff in an AE86 | megabob | 6 | 12,570 |
02-17-2015 03:37 PM Last Post: megabob |
| What Diff Oil For a Clutch plate diff? | jamieae86 | 10 | 18,718 |
12-16-2011 11:14 AM Last Post: bakonick |
| weight diff head diff center | fax0815 | 5 | 9,475 |
12-21-2010 03:03 PM Last Post: fax0815 |
| AE86 how many HP can the stock Diff handle?? | AE86-SA | 4 | 10,810 |
09-08-2009 11:03 AM Last Post: nmwisima |
| Celica F-diff with Hilux/ Pickup Torsen diff | Roye | 7 | 14,889 |
04-29-2008 09:13 PM Last Post: Roye |
![AEU86 AE86 - Gt86 diff in an ae86 [Image: AEU86 AE86 - Gt86 diff in an ae86]](https://www.aeu86.org/sticker-banner-468.gif)
