Group a homologation questions
05-11-2015, 09:31 PM
(This post was last modified: 05-11-2015 09:32 PM by ditn.)
So im checking the Group a homologation papers for the ae86 2 door and im wondering,
there is almost nothing in there that can be done to do the engine. Am im missing something or?? that cant be right for an ae86 grp a car rallycar |
05-12-2015, 01:52 AM
I have the full set of homologation papers, I'll have a look at mine. Maybe there are some differences.
Can you tell me the homologation number that you have ? An analogue brain in a digital World |
05-12-2015, 09:38 PM
A-5179 and n-5179 for grp a and grp n 2 door is mine.
i think its same. |
05-13-2015, 06:04 PM
(This post was last modified: 05-13-2015 11:59 PM by oldeskewltoy.)
from the A-5180 papers.... 3 door/hatchback
1599cc max minimum rod mass - 431 grams - length 122mm - big end diameter 43mm (so no 42mm cranks!) minimum crank mass - 11540 grams flywheel cast iron minimum mass - 7060 grams 55mm T/B injectors in head (not in intake) maximum valve lift - 7.2mm - clearances .2mm, and .25mm number of intake manifold elements - 2 (TVIS plate and intake??) exhaust cast iron max intake valve diameter 30.7mm, 6mm stem max exhaust diameter 25.7mm, 6mm stem wet sump oil system As I read it... that leaves a LOT of room for special machining, and head porting. It also has cam lift listed... but not durations.... no mention of compression ratios either.... no mention of adjustable cam pulleys either.... Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
05-16-2015, 02:46 PM
Some more engine info. here:
http://forums.toymods.org.au/index.php?t...3&start=0& An analogue brain in a digital World |
05-17-2015, 05:22 PM
thanks for info
![]() its really weird some say if its not in papers it has to be oem and other say if its not in papers its free. |
06-01-2015, 09:15 PM
someone from organisation came and he said everything thats not in the papers has to standard.
Kinda sucks,im going group n then |
06-01-2015, 09:37 PM
But isn't group n even more stict?
06-01-2015, 10:48 PM
(This post was last modified: 06-01-2015 10:57 PM by ditn.)
Yes its is,
But the truth is in group a with basicly a stock engine there is no way you can compete. However in group n its a very competitive car |
06-02-2015, 11:05 AM
Go group E1
| 20v Silvertop - New Haltech ECU & Couple of questions | 20valver | 10 | 8,557 |
| Windscreen stoopid(?) questions.... | Mylesmck | 7 | 4,582 |
| Brake Bias Questions | mad.matt | 10 | 16,404 |
| wider rear axle,track width,suspension questions | ditn | 6 | 12,982 |
| Suspension questions | leon205gti | 17 | 21,098 |
