Grey levin coupe.. http://fuzzyfeeling.blogspot.com/
07-12-2008, 07:55 PM
Post: #141
bubble,
without tuning the 4age you don't really need to do much. Good oil sprak plugs and stuff are the way to go. The standard injectors and fuel pump can easily manage the engine. Onle if you go diffrent camshafts you really have to work on the injectors. (fuel pump has overcapacity) you can also notice this by driving hard for 5 mins and checking the fuel gauge. then relax drive normal and you are "making" gas. The fuel meter will plus becuase the return line will be emptied in the fuel tank. If you keep up drifting I think you need a better engine. Either tune your 4age or drop in something else. But to get the engine loose. open pipe after the headers 2-1 (cut the piece where they merge and weld on a 55mm pipe (it works) (under diff possible) Open airfilter (only has use with a better exhaust and its not really a notice until you do some more to the car) Ok, this trick I didn't test myselve but seems to work for mid range power. Remove the fuel rail and the injectors. Now the end of the injector is a black thingy. pull it down (almost as if you want to take it off) this changes the spray of gas and seems to imporve mid range power (so i heard) Good oil (I mostly use semi synth on standard engines and full on rebuild) good spark plugs (one grade colder than standard) new sprakplug wires (if possible thicker. magnecor 10mm leads) Maintain the engine by changing the timing belt around the 40 K (you abbuse the engine so the timing belt stretches more than norma) change oil between 5k and 10k with filter. Always know that all the componments to let the engine work. (distributer cap etc when they are changed so you can maintain it in a healthy order) Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
07-13-2008, 09:58 AM
Post: #142
For what it's worth.. most modern engines run a bit lean and have white deposits on the valves and sparkplugs.. although I havent noticed this much with 4age's yet. It wont kill the engine.
07-13-2008, 11:22 AM
Post: #143
i dont know if the magnecor wires are so good, i think Toyota oem ones are better. I know one guy who sells them if you want. But i personally would stay with oem ones.
http://www.86ers.org All the hachies that Daytona can only dream about. |
07-13-2008, 12:45 PM
Post: #144
Decent plugs and leads, decent oil (i use only castrol 10w40), exhaust and air filter. Regular maintenance to keep everything happy, all this seems to work for me.
8k rpm all day long and it just keeps going, it even seems to run better if it's driven harder
No Smorking AE86 |
07-15-2008, 08:27 AM
Post: #145
Your car looks really cool! In fact it's one of the most good-looking 2dr levins I've seen!
As long as the spark plugs are regarded, there's a chance that your mixture is slightly lean. Can you upload any closeup images of the spark plug tip? JapanPower UoP Racing website UoP Racing videos Racing, because football, basketball, tennis & golf only require ONE ball.... |
07-16-2008, 09:09 PM
Post: #146
Thanks for the tips.
Still have one question. The engine gets really loud at 6700-7000rpm. Is this normal or what? |
07-16-2008, 11:35 PM
Post: #147
dunno, I've only noticed my engine getting really loud after being pushed beyond 5000rpm... it just started to scream a bit
I'd say, it probably is normal. Isn't the 6600rpm mark where the engine makes the most power in typical dyno's? Might be related ![]() btw, what spark wires did you get? Mine seem to be pretttttttty worn (part number and perhaps a price too? oh crap, just re-read, spark plugs. hehe. Well, still, same question Which plugs, and grade? Looking for new plugs as well ^_^
07-19-2008, 07:08 PM
Post: #148
Yeah I only changed the plugs.
NGK: BCPR6EY-11 I think I paid 12euro for four, but that is with a discount. |
07-19-2008, 07:12 PM
Post: #149
jup normal max power is around 6600-6800 rpm ... so its normal it would get a bit louder then.
07-21-2008, 01:05 AM
Post: #150
Amazing AE you got there mate, keep up the good work
| Trueno Hatch and Levin Coupe - Repair, replace, pray xD | TomRich | 13 | 20,855 |
| @dodo@ Levin Coupe, renovation and tuning (56k think twice) | @dodo@ | 165 | 203,911 |
| Aram's 3SGE Beams Levin Coupe | robokill | 665 | 896,453 |
| Matt's "Drives as fast as it's Towed" 85 Levin Coupe | mad.matt | 38 | 51,295 |
04-07-2016 12:15 PM Last Post: mad.matt |
| DidiDex 1984 Levin coupe rebuild | DidiDex | 1 | 7,233 |
08-13-2015 03:22 PM Last Post: DidiDex |
