Greddy Emanage ...
07-31-2008, 11:37 PM
Greddy Emanage ...
Interested in peoples views on the following:
I have been looking at cheap options for a programmable ECU, without butchering wiring looms, or going to the expense of full on stand alone systems. Lets face it even the cheapest EMS isn’t actually that cheap. The plan is I replace my existing dual carb set up and go back to EFI. In terms of modification I will fit ITB’s and a pair of 288 cams in the head. That’s where the engine management is needed to run the engine on the ITB’s and the cams – nothing scary. I am not going for massive performance, 150/160bhp will be amazing. I don’t care about drivability / refinement (the car is stripped considerably) I am only interested in peak performance for the track. So with everything considered and the relatively low state of engine tune I have been considering using a piggy back ECU rather than a stand alone system. The idea is they are cheap, pretty much plug and play, and will allow the small amount of adjustability I need over the engine to get it running properly and well on the cams and the ITB’s. As a result I have come across the Greddy Emanage Ultimate which looks like a good option. Its cheap … Prices are £250 or less for the system, loom and software! As it’s a piggy back no issue getting base maps / running other engine functions. I can map it myself if I want. Uses stock sensors and loom. All sounds good! So what’s the catch …. Has anyone used this system? Does anyone know anything about it – good or bad experiences? Have I over looked something with my application? Cheers James ![]() http://www.eight-six.co.uk - read the blog! UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk |
08-05-2008, 06:27 AM
Greddy Emanage ...
Can be used with a MAP setup and great for near NA mods.
08-05-2008, 01:25 PM
Greddy Emanage ...
Will it work ok taking a map reading from ITB's (will be equalised) and running long duration cams? Have some confilicting information on it - some say there will be issues some say not?
08-05-2008, 01:29 PM
Greddy Emanage ...
Yes it will work, bottom end driving will be rough but once its going should be an issue. IIRC your cars a track car so wont get much low revs use.
I'm currently taking HRT ~ Hachi Roku Therapy |
08-12-2008, 06:04 AM
Greddy Emanage ...
E manage Ultimate is the best system to get. More powerful processor and upgraded cooling for great reliabity.
11-16-2008, 10:22 AM
Greddy Emanage ...
Can i use it for CR 11,3:1 and cams 272 10,3 lift?
With those cams can i use the stock ecu (only that)? ll Start engine? **COROLLA EE80 - 4AGE 124HP**
| Emanage set up | eight-six | 17 | 27,830 |
07-30-2009 06:15 AM Last Post: uniquetrueno |
| Emanage - software / data cable | eight-six | 10 | 13,197 |
06-25-2009 01:42 PM Last Post: eight-six |
| *new* Greddy Type-S Suspension / Remote Control Unit | kid | 7 | 9,090 |
01-09-2008 10:40 PM Last Post: kid |
| greddy emanage ultimate on 4agST | mmv | 1 | 3,721 |
04-15-2007 06:02 PM Last Post: mmv |
| Greddy Coilovers | apardal | 14 | 17,023 |
04-04-2007 11:40 PM Last Post: oldeskewltoy |
![AEU86 AE86 - Greddy Emanage ... [Image: AEU86 AE86 - Greddy Emanage ...]](http://i57.photobucket.com/albums/g239/N2AE86/memberbanner1jpg.jpg)
