Going 20V BT!
10-02-2012, 12:18 AM
Going 20V BT!
Heyo guys!
It's time to think about other ways on my refreshed Levin now Trueno... The engine marks 170000Km's and it's now giving me valve noises sign that this engine needs a tune! Well, about this tune i now face 3 options... - A complete overhaull on my current engine (probably never opened) - A small fix on the engine (saving money to buy something better) - A 20V that is my final goal when i talk about engines My engine doesn't knock whatsoever and has alot of power to give, last week i made a national gathering in Portugal and the engines handled it like a bawss... so.... The issue here is the 20V fixing... What are really my options when using the 20V ECU? I don't wanna go squirt... Keeping the stock ECU on the 20V is my goal. Relocate the dizzy: I know i have to relocate it... But, what are my options? COP's - Can i run COPS and use the stock ECU? How so? Will i have wasted sparks? Thanks for the input! |
10-02-2012, 07:05 AM
Going 20V BT!
If you are going 20V BT, then I strongly recommend that you use the
factory ECU, factory trumpets and airbox (modified for RWD) and the factory ignition system. COP's do nothing for performance, and can cause a lot of grief if they don't work well first up. Keep the dissy and modify the firewall. If you don't want to do that, get a quality dissy relocation kit, and put it in front. Seriously... if you want an engine that starts and runs like stock... keep everything factory. The 20V BT is highly optimised from the factory, and you really have to know what you are doing to improve on the factory setup. If you like modifying (and who doesn't ) then do the swap with everything stock, and drive it for 6 months. That way, you know if your modifications are making your car better or worse. Cheers... jondee86 |
10-02-2012, 03:31 PM
Going 20V BT!
I will go 20V to run it stock! Stock engine + stock ECU.
The problem here is that i don't want to knock the firewall. Of at least that is not on my current plans... Do i have good solutions when using a dizzy relocate kit? What are my best options here? About banging the firewall, how much do i have to bang to fit the 20V? It's a pitty that i have to destroy my clean firewall..... The solution when running COP's + stock ECU is that i can fir the 20V w/o banging the firewall which is like the thing i want. Thanks for the input jondee! |
10-03-2012, 02:05 AM
Going 20V BT!
Have a look here... http://s-86.com/s-parts-dizzy-kits.html
Relocates high tension parts to the front, and leaves the electronics at the back. You can get the alloy cover for the electronics to keep them safe. s-86 also do water relocation kits, so you could get proven product at reasonable prices, and combine for shipping ![]() Sam provides good backup, speaks English, and is active on the forums if you need to ask any questions. Cheers... jondee86 |
10-03-2012, 05:40 PM
Going 20V BT!
i would go COP, with OEM parts on a stock engine i say it will work fine
10-03-2012, 06:14 PM
Going 20V BT!
What's the downturn running COP's with stock engine and OEM ECU?
10-03-2012, 07:03 PM
Going 20V BT!
to be honest im only experienced with COP on honda's, and there they fail beacuse of heat or not maintained right
they overheat, melt to the sparkplug and the tip of the sparkplug melts too. the tip Drops in the Zylinder ... on the early s2000 it's a common Problem, because of maintenance lag on the turboed honda's because of massive heat |
10-03-2012, 09:24 PM
Going 20V BT!
pack Wrote:What's the downturn running COP's with stock engine and OEM ECU? The factory ECU is not designed to run COP's. So you have to retain the igniter (and sometimes coil also) to provide the IGf and IGt signals that the ECU requires. Then you finish up with four "dumb" coils sitting on top of the plugs, batch firing at four times the rate they were designed to fire. It can be made to work, but offers no performance advantage over the stock ignition system. Club4AG has hundreds of threads detailing the problems people have with getting the DIY COP's to function. So I suggest that if you want a system that works like factory with no problems, stay with the dissy and relocation kit. But if you want the "look" of COP's, and don't mind getting your car towed home now and then, get a set of Civic COP's. s-86 even do a COP mounting plate ![]() Cheers... jondee86 |
10-03-2012, 09:30 PM
Going 20V BT!
yes jondee you are right, it's not giving you any more power or Performance
it's just a cleaner and nicer solution, but in pack's case the dissy relocation kit is the better option |
10-03-2012, 10:13 PM
Going 20V BT!
I'm only reading inputs to decide previously my move, if you know what i mean....
Thanks for the input! I also think that a dizzy relocation kit is a better option than running COP's, i really want to look stock! Right now i don't have any more questions besides some water relocations kits, and using the 16V water pump.... I'm also reading a ton of projects about 20V swaps! Any decent ones you know for me to read? Thanks |
| Effects of valve lift - worth it going higher? | harkes | 18 | 24,374 |
03-17-2014 09:21 PM Last Post: oldeskewltoy |
| Machining Pistons to run 20v head... And FCR's on a 20v? | PazzaAE86 | 2 | 7,168 |
| T50 weird gear set What´s going on? | fax0815 | 13 | 52,382 |
08-13-2012 04:50 PM Last Post: Project D |
| Revs going up and down... | Okami | 8 | 12,727 |
06-28-2012 07:25 PM Last Post: Okami |
| Idle not going smooth... | pack | 12 | 17,824 |
06-13-2011 10:40 PM Last Post: adenAE86 |
