Getting rear discs off ...
06-11-2006, 06:54 PM
Went to change my rear discs and pads and the disc's were welded to the hubs. Had this in the past with other cars and a good wallop with a mallet normally shakes the disc free but no such luck this time.
Looks like I may need to use my puller (didnt have it to hand).
Is it common for the AE back brakes to be this stubborn? Am I missing a trick here before I go crazy on it and do some damage?
Cheers
James
[Image: AEU86 AE86 - Getting rear discs off ...]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
06-12-2006, 12:31 AM
On rear discs you have two little holes.
Find proper screw and screw iz in it.
Dics will go off.
Screw slowely first and then second and then first..........
Don't ruin your discs by forcing too much on one screw.
1984 AE 86 Levin hatchback
1989 AE 92 GTi
2004 Kawasaki KLE 500
06-12-2006, 08:45 AM
Indeed. See also step 6 in my how to:
http://www.aeu86.org/Writeup/Brakesystem...index.html
I didn't need to use it, but mux pointed me at it. Wink
06-12-2006, 10:54 PM
Cool thanks fellers,
Thought as much but didnt have a suitable bolt. If I had all my tools on me I would have just used my crank pulley puller. Going to screw that onto each side of the disc and pull it out straight. Should avoid any further hammering. Wave
  Handbrake adjustment discs? DMC 8 5,978 03-10-2024 08:08 PM
Last Post: DMC
  20V blacktop. what kind off ecu??? slowboy2 11 19,173 07-17-2015 07:01 PM
Last Post: jdm86gtz
  getting new sparkplugs, or keep away ? MC_JP 5 9,085 09-19-2014 11:35 PM
Last Post: Project D
  Car shutting off and ECU making noise rawb_dbap 8 11,397 05-03-2013 11:51 PM
Last Post: rawb_dbap
  Rear ae86 rear discs & pad part numbers? J-86 4 8,556 11-30-2012 06:32 PM
Last Post: J-86
