GZE wiring fault
11-14-2008, 03:47 PM
GZE wiring fault
Hi guys,
my issue is with the black 2 pin connector next to the battery.
This provides +12v on both pins when ignition on, and 0v when ignition off
One pin provides power to the ECU, unsure on what the other one is for.
I have wired up my injectors to this line. So they turn on at the right time.
My problem is when I turn ignition off, the engine still runs, even though I have measured this plug at 0v
When I disconnect the connector, the engine stops running.
If I disconnect the battery in this state the engine carries on running! I believe this is because the alternator provides power to the power line still, but I don't see how it has a full circuit connection to the negative side of the battery when I disconnect that.
So what have I done wrong? Confused
11-15-2008, 06:48 PM
GZE wiring fault
Never mind chaps, I sorted it now Thumbs up!
  DLI GZE no spark 4agetercel 5 8,919 02-01-2013 07:05 PM
Last Post: 4agetercel
  GZE Swop with PAS & AC Lauren 12 17,507 02-16-2012 01:04 PM
Last Post: heshan
  Engine sounds slush GZE with VIDEO ! Okami 13 18,486 01-03-2012 12:12 PM
Last Post: Okami
  GZE swap in a SR5 TomTom15 3 5,798 11-04-2011 12:30 PM
Last Post: MatthewG
  GZE pulleys NEW question Okami 15 26,010 09-30-2011 07:08 PM
Last Post: Lauren
