GOLDEN EAGLE VACUUM MANIFOLD
07-13-2008, 01:06 PM
just bought one of these to go with my itb setup, what way do i install the pipes to work the map sensor
07-13-2008, 01:09 PM
If you are on 20v itbs you will notice there is a vacuum nipple on each of them...take the vac lines from here into the vacuum collector. Or... you can tap nipples into the ITB adapter/manifold.
This was my old 4AGE setup.. ![]() I didnt use the outlets on the ITBS - the vac was taken straight from the manifold...but you can see the places on the ITBS themselves (have the short runs of blocked vac pipe on them). Use the one-way valve on the golden eagle item to go to the brake booster, and use another outlet for the map sensor. Are you going to try and run a std ECU ? if not you dont especially need the map sensor as you'll be able to map on throttle position. Hope that helps. Regards Ian. |
07-14-2008, 06:36 PM
yeah that's great tanx, no tryin to run megasquirt nearly have it wired. what were you running with?
| Smallport inlet manifold | totta Crolla | 6 | 6,329 |
01-17-2022 05:14 PM Last Post: oldeskewltoy |
| US-spec vacuum hard lines | LordTD | 2 | 7,115 |
04-27-2015 07:18 PM Last Post: Project D |
| 4age blue top from MR2 same intake manifold? | dinkers542 | 8 | 14,698 |
11-02-2014 05:24 PM Last Post: ditn |
| VALVE ASSY, VACUUM SWITCHING, what's this for ? | Uzelac | 10 | 20,470 |
11-22-2013 10:40 PM Last Post: jondee86 |
| 4AGTE turbo manifold questions | daveskatesallday | 3 | 6,825 |
08-13-2013 07:38 PM Last Post: daveskatesallday |
![AEU86 AE86 - GOLDEN EAGLE VACUUM MANIFOLD [Image: AEU86 AE86 - GOLDEN EAGLE VACUUM MANIFOLD]](http://aspian.dnsalias.com/images/ae86/48.jpg)
