GAUGES - which?
02-09-2007, 10:44 PM
GAUGES - which?
i personally have only 1 gauge and it is an iEquus water temp gauge. they're affordable and they're more for utilitarian rather than show purposes. they look decent and i plan on picking up another to use it as an oil temp gauge. temp is temp right.
[Image: AEU86 AE86 - GAUGES - which?]
"Strictly All Things 86"
02-10-2007, 02:07 AM
GAUGES - which?
dr.occa, i have an opportunity to buy them Equus very cheap, so im wondering about their exactness? Would you say the perform good and conistently?
02-10-2007, 02:53 AM
GAUGES - which?
Apolan - you hit the nail on the head... properly installed gauges work... if they don't the manufacturer will take them back. Autometer, Equus(new one to me...) VDO, Smiths.... the name isn't that important... Remember this isn't the shuttle... or a Viggen, this is just a car(we all love our cars). a 5% error on oil pressure isn't going to be important... btw... anyone ever calculate the amount of error in OEM stuff??? Here is what I WOULD recommend... buy new, and THINK about what you want, BEFORE you buy. Oh... and only buy the name brand stuff(Defi... HKS... GReddy...) if YOU want it... NOT because someone said you should
Dan -
02-10-2007, 03:11 AM
GAUGES - which?
for all i care it can say NKS or BReddy, as long as it does the job. And on the sidenote, i dont want something bright and flashy that would
Ivan141 Wrote:stand out like a turd in a punchbowl on an ae86 dash,
Okay, more importantly now.. where should i mount the senders to get the most accurate readings?
what do you think about this adaptor plate that goes under the oilfilter.
BTW: im looking for oiltemp and oil press.
02-10-2007, 03:23 AM
GAUGES - which?
very common thing. The oilfilter adapter plates. Easy safe way of plugging in some sensors. Not bad.
02-10-2007, 03:24 AM
GAUGES - which?
oil temp can go whereever you want... some people like to see oil pan temps, others can take the temp from the filter. For pressure take it from the OEM pressure point, it is the MOST reliable.
Dan -
02-10-2007, 03:27 AM
GAUGES - which?
But im not sure.. because oil goes through the oil cooler than to the filter and than to the sender and on to the cranckshaft.. So what i would get is a reading of the chilled oil.. so when i would push the engine hard for a longer period of time i would get the reading of say 120'c, where in fact the oil in the engine would be at over 130-140'c ??
02-10-2007, 04:19 AM
GAUGES - which?
Apolan Wrote:dr.occa, i have an opportunity to buy them Equus very cheap, so im wondering about their exactness? Would you say the perform good and conistently?
honestly, i've never tested my water temp w/ let's say an infrared temp gun (i plan to soon) but i have both the equus and the stock cluster water temp gauges going for general comparison. the water temp provides the numbers instead of "you're getting warmer" info that the factory gauge gives you.
i do like the oil filter adapter there. who's the manufacturer and where can i get one Yummie!
02-11-2007, 12:48 PM
GAUGES - which?
PASS racing makes some similar adapter plates, but I would prefer thermostatic bypass instead of full flow oild cooling for a street car.
02-11-2007, 03:43 PM
GAUGES - which?
http://www.demontweeks.co.uk/
Demon Tweeks are selling VDO gauges.
  20v BT - which oil pump? Mylesmck 4 6,123 06-21-2022 04:51 PM
Last Post: pack
  Rim width. Which is best.... Dino86 5 10,152 01-07-2017 03:09 PM
Last Post: Dino86
  which connector is this ditn 7 11,581 07-27-2015 11:24 AM
Last Post: pack
  Haslbeck front spoiler, which foglights? wouter86 2 7,319 02-15-2015 11:14 AM
Last Post: ditn
  which piston is this? ditn 10 16,744 07-04-2014 03:18 PM
