Full restoration...
02-15-2014, 04:44 PM
Post: #31
Full restoration...
if I may, as your engine is still out and empty. You could smooth the surface below the cylinder. You will see that one of the main oil canals has a not so clean exit into the lower part of the engine.
I heard from an engine builder that it decreases drag if the surface of the bottom of the engine is cleaner. (some engine tuners use a coating to achive the same effect quicker than sanding/grinding it smooth. I did it on one of my project engines and it takes time and a good cleaning. But I guess once done it is something you never have to worry off again :-) Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
02-17-2014, 10:00 AM
Post: #32
Full restoration...
Hi Robokill,
thanks for your tip, I will check it |
02-24-2014, 11:10 AM
Post: #33
| Full restoration... | |||
02-25-2014, 01:53 PM
Post: #34
02-26-2014, 03:57 PM
Post: #35
Full restoration...
Hi Guys,
Could someone please clarify if the head resurfacing needed all the time when engine got disassembled? thx, Dima My car even older than I. Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD |
03-03-2014, 07:49 PM
Post: #36
Full restoration...
not always needed. But then you really need to clean it properly. You can use resurfacing to get it completely straight but you would also need to do the lower block of the engine to make sure both are lvl.
To increase compression it is even advised to take some of the lower block and not the head as the head is more fragile. Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
03-17-2014, 10:20 AM
Post: #37
Full restoration...
So, die Ventile sind vermessen und der kopf ist drauf
[URL="http://abload.de/image.php?img=p1310477vrkeu.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310479nlkal.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310480b7j7g.jpg"] [/URL]above 7A under 4A gasket watch on the right side... the two water channels are not existing in the 7A gasket.... I self maded it [URL="http://abload.de/image.php?img=p1310484x1keg.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310486s4jfc.jpg"] [/URL][URL="http://abload.de/image.php?img=p13104876rknk.jpg"] [/URL][URL="http://abload.de/image.php?img=p13104864vkcm.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310488eyknj.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310489ahj39.jpg"] [/URL]
04-17-2014, 08:13 AM
Post: #38
Full restoration...
Hi guys,
some updates. [URL="http://abload.de/image.php?img=p1310625mfjv5.jpg"] [/URL]I use the Paseo clutch... we have checked everything, and it looks very good we say us, "ok let's try the paseo clutch [URL="http://abload.de/image.php?img=p131062699jw7.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310627btkrj.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310628ewkyk.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310629iqjer.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310630vxkw8.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310632i6k3o.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310634arjp1.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310635pvk8u.jpg"] [/URL][URL="http://abload.de/image.php?img=p131063823kxg.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310639thk2x.jpg"] [/URL][URL="http://abload.de/image.php?img=p13106411bjd2.jpg"] [/URL]grüße Marco |
06-04-2014, 11:51 AM
Post: #39
Full restoration...
[URL="http://abload.de/image.php?img=p1310907czrck.jpg"]
[/URL][URL="http://abload.de/image.php?img=p13109117ur3n.jpg"] [/URL]turn the lights on... [URL="http://abload.de/image.php?img=p1310913v2j3g.jpg"] [/URL][URL="http://abload.de/image.php?img=p131091415jlm.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310916gjkt5.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310918bmjk0.jpg"] [/URL]a new construction for the roof window... [URL="http://abload.de/image.php?img=p1310919z6fgw.jpg"] [/URL][URL="http://abload.de/image.php?img=p131092060cqf.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310921tksvx.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310922c9siz.jpg"] [/URL][URL="http://abload.de/image.php?img=p1310923r6s5q.jpg"] [/URL]greets Marco |
06-27-2014, 04:11 PM
Post: #40
Full restoration...
nice work. Can't you use a 3d printer to make that plate?
Is that a is200 or an altezza in the back ? Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
| Another danish restoration | Duze | 61 | 95,031 |
03-20-2016 08:58 AM Last Post: Duze |
| '84 ae86 restoration project | HybriD07 | 19 | 33,234 |
10-13-2014 09:20 PM Last Post: HybriD07 |
| TOYOTA COROLLA Ke70 - Restoration project | cke70 | 34 | 67,421 |
07-02-2014 10:12 PM Last Post: cke70 |
| Black Limited restoration | slpery86 | 6 | 12,972 |
12-17-2013 09:22 PM Last Post: banpei |
| A.D.D Performance AE86 RESTORATION NEARLY COMPLETE | cab32 | 24 | 39,567 |
08-08-2013 09:27 AM Last Post: Martynas |
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310351hlu0h.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p13103526tu3w.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310357ipuci.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310358mrup0.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310359o6uwe.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310360vkuz1.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p13103712bu98.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p13103655ruoi.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310356wquf9.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310361wtuvz.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310368ygu7o.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310369rvuog.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310373p1sg1.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310376zns13.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310382ojsaq.jpg)
![AEU86 AE86 - Full restoration... [Image: AEU86 AE86 - Full restoration...]](http://abload.de/img/p1310383zjs8z.jpg)
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
