Full restoration...
02-15-2014, 04:44 PM
Post: #31
Full restoration...
if I may, as your engine is still out and empty. You could smooth the surface below the cylinder. You will see that one of the main oil canals has a not so clean exit into the lower part of the engine.
I heard from an engine builder that it decreases drag if the surface of the bottom of the engine is cleaner. (some engine tuners use a coating to achive the same effect quicker than sanding/grinding it smooth.
I did it on one of my project engines and it takes time and a good cleaning. But I guess once done it is something you never have to worry off again :-)
02-17-2014, 10:00 AM
Post: #32
Full restoration...
Hi Robokill,
thanks for your tip, I will check it
02-24-2014, 11:10 AM
Post: #33
Full restoration...
Hello, some updates...
[Image: AEU86 AE86 - Full restoration...]
Marco
02-25-2014, 01:53 PM
Post: #34
Full restoration...
02-26-2014, 03:57 PM
Post: #35
Full restoration...
Hi Guys,
Could someone please clarify if the head resurfacing needed all the time when engine got disassembled?
thx,
Dima
My car even older than I.
Dec. 1983 zenki Levin coupe AE85 swapped to 4age16v from ae92 and other needed stuff and RHD to LHD
Nov. 1985 kouki Trueno hatchback AE85, with 86s suspension, @3A + A42DL, RHD
03-03-2014, 07:49 PM
Post: #36
Full restoration...
not always needed. But then you really need to clean it properly. You can use resurfacing to get it completely straight but you would also need to do the lower block of the engine to make sure both are lvl.
To increase compression it is even advised to take some of the lower block and not the head as the head is more fragile.
03-17-2014, 10:20 AM
Post: #37
Full restoration...
So, die Ventile sind vermessen und der kopf ist drauf
[URL="http://abload.de/image.php?img=p1310477vrkeu.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310479nlkal.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310480b7j7g.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
above 7A
under 4A gasket
watch on the right side... the two water channels are not existing in the 7A gasket.... I self maded it
[URL="http://abload.de/image.php?img=p1310484x1keg.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310486s4jfc.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p13104876rknk.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p13104864vkcm.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310488eyknj.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310489ahj39.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
04-17-2014, 08:13 AM
Post: #38
Full restoration...
Hi guys,
some updates.
[URL="http://abload.de/image.php?img=p1310625mfjv5.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
I use the Paseo clutch... we have checked everything, and it looks very good
we say us, "ok let's try the paseo clutch
[URL="http://abload.de/image.php?img=p131062699jw7.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310627btkrj.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310628ewkyk.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310629iqjer.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310630vxkw8.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310632i6k3o.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310634arjp1.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310635pvk8u.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p131063823kxg.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310639thk2x.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p13106411bjd2.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
grüße
Marco
06-04-2014, 11:51 AM
Post: #39
Full restoration...
[URL="http://abload.de/image.php?img=p1310907czrck.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p13109117ur3n.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
turn the lights on...
[URL="http://abload.de/image.php?img=p1310913v2j3g.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p131091415jlm.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310916gjkt5.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310918bmjk0.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
a new construction for the roof window...
[URL="http://abload.de/image.php?img=p1310919z6fgw.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p131092060cqf.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310921tksvx.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310922c9siz.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
[URL="http://abload.de/image.php?img=p1310923r6s5q.jpg"][Image: AEU86 AE86 - Full restoration...][/URL]
greets
Marco
06-27-2014, 04:11 PM
Post: #40
Full restoration...
nice work. Can't you use a 3d printer to make that plate?
Is that a is200 or an altezza in the back ?
  Another danish restoration Duze 61 86,394 03-20-2016 08:58 AM
Last Post: Duze
  '84 ae86 restoration project HybriD07 19 30,151 10-13-2014 09:20 PM
Last Post: HybriD07
  TOYOTA COROLLA Ke70 - Restoration project cke70 34 61,726 07-02-2014 10:12 PM
Last Post: cke70
  Black Limited restoration slpery86 6 11,791 12-17-2013 09:22 PM
  A.D.D Performance AE86 RESTORATION NEARLY COMPLETE cab32 24 35,777 08-08-2013 09:27 AM
Last Post: Martynas
