Fuel sender unit
09-02-2008, 03:48 AM
Fuel sender unit
Hi All,
I have a broken fuel sender unit and am looking at replacing it with a generic brand. Can anyone tell me what the resistance of the full and empty levels should from the sender?
Thanks,
Vernon.
09-02-2008, 09:42 AM
Fuel sender unit
You can slide a multimeter across the coil in the sender unit to determine the resistance, unless of course you've broken the coil, in which case, WTF?!!
Have a look on http://www.autoshop101.com One of the tech docs may have that data
09-02-2008, 11:32 PM
Fuel sender unit
The unit is completely stuffed, otherwise I would have done as you suggested. I tried cleaning and inspecting the wires, as you say the coil must be broken. Thanks for the link, I will check it out and see if it can tell me what it need.
BTW: It is an AE101 jap import (4age silvertop), if anyone else has the data handy.
Cheers,
Vernon.
09-03-2008, 05:33 AM
Fuel sender unit
The fuel sender unit can be cleaned if the contacts are dirty with lots of build up.
1987 328ci SR20DET Drift Car
2002 Corolla CE Daily Driver
http://www.TheTunerSource.com
09-03-2008, 07:15 AM
Fuel sender unit
Have you physically inspected the coil? I'm not saying it's impossible, but I find it very hard to believe that the coil has separated! You should be able to open the unit up so that the coil and contacts are exposed.
When I bought my sprinter I had to bend the slider on the top of the float arm so that it made solid contact with the coil, and the fuel gauge has now been working for 6years.
09-03-2008, 07:41 AM
Fuel sender unit
Had it in bits, looks like someone else has had their hands in it and not been careful. Or taken to it with the wrong tools. Off to the wreckers this weekend for a replacement I would say. Smile
  How to: Repair low fuel warning sender Sanity Clause 3 42,256 05-19-2025 11:05 PM
Last Post: Sanity Clause
  Water Temperature Instrument not moving - Sender Gauge Hama86 8 11,616 12-06-2017 06:48 PM
  WTF is that? speedodrive sender adaptor thingy.... fax0815 8 15,467 09-14-2015 12:16 PM
Last Post: pack
  Original gauge with universal fuel sender Komba 4 8,795 01-05-2015 03:27 PM
Last Post: Komba
  AE86 heat unit panel with buttons and sliders Okami 6 13,215 09-09-2012 04:09 PM
Last Post: Okami
