Fuel pump
12-07-2005, 06:19 PM
Fuel pump
I want to replace my old fuel pump. I’ll keep engine as it is, so there’s no need for big upgrades.
Q: Any suggestions for fuel pump replacement?
Q: Is there any other type I can use?
Thx.
Fun is not the straight line!
12-07-2005, 06:39 PM
Fuel pump
3SG(T)E, 7MGTE pumps are bolt-on.
You can use also external pumps from K-Jethronics Mercedes, Audi etc.
12-07-2005, 07:37 PM
Fuel pump
jep, doesnt have to be an iternal one at all.. considering you are in croatia, it might be alot easier fot you to get a german pump. Mine i think is from a golf or some other VW. works fine, it just starts to bog if the tank gets too empty.
12-07-2005, 09:19 PM
Fuel pump
Impreza also fits
[Image: AEU86 AE86 - Fuel pump] http://www.jdmbits.com
12-07-2005, 10:31 PM
Fuel pump
and where can we find such pumps for a reasonal price?
12-08-2005, 12:24 AM
Fuel pump
When you tune your car Alimonos you should go for a CelicaSupra fuel pump (tell me when you want it and i ll try to find one) and a new fuel pressure regulator (again let me know).
12-08-2005, 08:14 AM
Fuel pump
RX7 FC fuel pumps are pretty much a direct replacement as well.. The only thing you need to swap over from the old pump is the fuel strainer (filter), and take off some stuff where the pump attaches to the fuel pipe.
12-08-2005, 10:14 AM
Fuel pump
FPR i have allready found so nmwisima go for that Celicasupra pump!
12-08-2005, 10:16 AM
Fuel pump
alimonos Wrote:FPR i have allready found so nmwisima go for that Celicasupra pump!
Why you want to replace yours ?
12-08-2005, 10:22 AM
Fuel pump
The only valid reasons to replace a fuelpump are:
1. The old one is broken..(duh)
2. Fuel capacity not enough..mostly a problem that turbo cars develop.
There is no point in installing fancy fuelpumps if there is no need for extra capacity..you will just be pumping fuel around pointlessly.
  20v BT - which oil pump? Mylesmck 4 6,127 06-21-2022 04:51 PM
Last Post: pack
  Fuel pump issue DJexor 11 11,965 04-29-2022 05:45 AM
  fuel line hose from the pump Wikizz 4 8,693 10-16-2017 07:11 PM
Last Post: jdm86gtz
  4age smallport oil pump in bigport engine? ditn 2 10,498 12-06-2014 08:10 PM
Last Post: ditn
  Oil pump question megabob 2 6,589 03-05-2014 05:37 AM
