Front brake discs from another car?
09-14-2006, 05:37 PM
Hello there,
I have serious question: is there any car model, that's front brake discs would be exhactly the same as the ae86
White ae86 Levin |
09-14-2006, 05:57 PM
Nookie, try finding the discs you need on ebay... or find a company that imports a lot of carparts cause they can usually find what you need.
We have webshops that sell them in holland too..but it's cheaper to find them locally. FABRICA MI DIEM, PVNC! |
09-14-2006, 05:59 PM
asiliuk, taigi sakiau, kad galiu tau juo parupinti!!!
eng: doode, i told you that i can source em to ya!! adam |
09-14-2006, 06:30 PM
i think ae86 disc can be aranged, at last from ebay.de.
But another question, what for disc to use with FC3S caliper if i not accept the measures of FC3S discs? http://www.86ers.org All the hachies that Daytona can only dream about. |
09-14-2006, 08:20 PM
I have been thinking lately about brakediscs. Wouldn't the old celica supra fit as well ?
09-14-2006, 11:00 PM
nope, i've got a set of Celica GTS (also 4A-GE) front brakes.
They are quite a lot bigger, but everything is different. Could be a nice upgrade, but it's a lot of work, sadly.
09-18-2006, 11:59 AM
If you use the RXY 4pot calipers you need a special mounting bracket.
the discs are from an Integra Type R DC2 i think, thats what i run Its gotta go whoosh or give a whine!!!! |
09-18-2006, 12:10 PM
ITR discs are the same as the accord aerodeck VTEC..these are quite a lot cheaper usually.
09-18-2006, 12:13 PM
Yea but try buy a set of up rated after market aerodeck discs?
09-18-2006, 12:31 PM
You could try to use s13 discs(pump) mcphersons,knuckles. arms. tie rods. Its a lot of stuuf but when you done it you have a lot of negative camber better brakes.
KAE70--> http://www.youtube.com/watch?v=VJasjMGVd7k Ae86 daily drift car rebuild |
| Handbrake adjustment discs? | DMC | 8 | 5,474 |
| Front big brake kit | DidiDex | 14 | 24,072 |
10-24-2016 09:29 AM Last Post: FanIsHere |
| Rear ae86 rear discs & pad part numbers? | J-86 | 4 | 8,278 |
| Toyota partnumbers OEM brake lines (front) | IBMFD3S | 6 | 9,648 |
01-10-2012 06:36 PM Last Post: bozu |
| Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 17,786 |
03-03-2011 12:06 AM Last Post: filh |
