Front big brake kit
02-22-2015, 12:29 PM
Front big brake kit
I would not recommend grp4. The kit that I bought for my 86 did not fit, the rotors. I gave them back the kit and they refunded me. I finally took the t3 kit that fit perfectly. I have just replaced my master cylinder by a Nissan tercel one to have a less spongy feel. I did not try the car yet.
my toyota is fantastic
02-22-2015, 01:32 PM
Front big brake kit
I have fitted the GRP4 kit without any problem
02-22-2015, 06:52 PM
Front big brake kit
I'm not sure if they're available yet, but this kit looks amazing: http://www.modception.com/products/ae86/...-brake-kit
02-22-2015, 07:38 PM
Front big brake kit
When was that floss.ie? It seemed to work before but recently I do not think it is the case. You should have seen how they made the holes of the brackets. It was nasty. Glad it worked for you.
10-24-2016, 09:29 AM (This post was last modified: 10-24-2016 09:29 AM by FanIsHere.)
Front big brake kit
(01-31-2015 10:45 AM)T_AE86 Wrote: [ -> ]If it can helps you: I use the "old" T3 Wilwood kit (basically the same of GPR4), i had a problem because my brake booster - BMC was zenki...a bit small than kouki, the pedal was too soft. I replace the BMC for a 1" Hiace's one (with starlet EP71 deposit because hiace's one touched the booster) and now is a bit hard...and works perfect!!
Is the 1'' BMC from Hiace a plug&play one for Zenki's brake booster (2-bolts)?
If yes, can I have the part number of it? Or at least the exact model of Hiace?
[Image: AEU86 AE86 - Front big brake kit]
Follow: The story of my AE86
  4AGE Big port head failure Blaze0010 3 1,776 01-23-2026 03:35 PM
Last Post: totta Crolla
  Big wheel problems gh0st 16 16,509 11-15-2021 10:51 PM
Last Post: gh0st
  20v mains & big end bearing izanagi 9 15,094 12-26-2016 12:42 PM
Last Post: pack
  Toyota partnumbers OEM brake lines (front) IBMFD3S 6 10,308 01-10-2012 06:36 PM
Last Post: bozu
  changing from electric moter windows to winders big job? irish ae86 5 8,978 03-31-2011 08:39 PM
Last Post: Dogger
