Front big brake kit
01-29-2015, 11:02 PM
Front big brake kit
I'm thinking of ordering a big brake kit. The original plan was to build a street car that could do some trackdays.. But it is turning into a track car that is kinda streetish..
So original plan was this:
http://mcnsport.com/products/ae86-wilwoo...nch-wheels
Decent kit for a good price! But then I found this kit:
https://technotoytuning.com/toyota/ae86/...86-corolla
Is the T3 kit worth the extra 400 euro? I'm not planning on using a pedal box and the stock brake booster is kept.
I used a set of AP Racing big brakes on my AE82 and they were awesome. Could just fit a 15 inch wheel, and stopped like hell!
01-29-2015, 11:39 PM
Front big brake kit
Ap racing brakes are probably the best you can get.
If you can afford it i would buy them for the ae86 as well.
01-30-2015, 01:00 AM
Front big brake kit
300mm brakes squeezed under an AE86?? After what power figures are you after to need such huge brakes on a >1000kg car? Wink
The 275mm mcnsport wilwood kit is all you need for a streetable track hachi and has been proven to work great.
Daily Beater: Civic EG5
Work in progress Car: AE86
01-30-2015, 10:13 AM
Front big brake kit
I would like something to match the power of the Ap's..
I bought a complete AE82 without engine for 400 euros. When I got home and took the wheels of, my jaw literately dropped when I saw the AP's on it Smile I would like them back but they are to expensive to buy new..
01-30-2015, 11:38 AM
Front big brake kit
You also can choose the rx7 caliper with mini disc brake option.
Or i have brackets that allow you to use the 2 pot front calipers of a mr2 sw20 with its 280mm rear disc's (have to be redrilled). My setup uses readily available toyota parts. Only thing is i have to get new brackets made as i don't have any in stock.
AE86 Levin
01-30-2015, 11:45 AM
Front big brake kit
Willwoods are VERY capable indeed. Used in plenty of high echelons of motorsport and (oddly) don't have the price tag of AP.
Pads CAN be more expensive here in Europe as an American manufacturer but their calipers are very good.
Modception do a cylinder upgrade too - http://www.modception.com/products/ae86/...r-cylinder
01-30-2015, 11:51 AM
Front big brake kit
I'm running RX7 alloy callipers with Mini Cooper discs. It's a fantastic set-up. My car is 270bhp
01-30-2015, 12:52 PM
Front big brake kit
True... RX7 brakes. Cheap and optimal for our car weight.......
01-31-2015, 10:45 AM
Front big brake kit
In GPR4 you can buy a Wilwood kit (Wilwood forged Dynalite 4 pistons calipers + 280mm slotted and drilled discs) at good price
If it can helps you: I use the "old" T3 Wilwood kit (basically the same of GPR4), i had a problem because my brake booster - BMC was zenki...a bit small than kouki, the pedal was too soft. I replace the BMC for a 1" Hiace's one (with starlet EP71 deposit because hiace's one touched the booster) and now is a bit hard...and works perfect!!
The wilwood BP10 pads had the "cold problem" and replaced it by EBC Yellowstuff...the car brakes a lot, no blocking easily, no weary...
[Image: AEU86 AE86 - Front big brake kit]
02-10-2015, 04:51 PM
Front big brake kit
thanks for the info!!
  4AGE Big port head failure Blaze0010 3 1,784 01-23-2026 03:35 PM
Last Post: totta Crolla
  Big wheel problems gh0st 16 16,529 11-15-2021 10:51 PM
Last Post: gh0st
  20v mains & big end bearing izanagi 9 15,104 12-26-2016 12:42 PM
Last Post: pack
  Toyota partnumbers OEM brake lines (front) IBMFD3S 6 10,309 01-10-2012 06:36 PM
Last Post: bozu
  changing from electric moter windows to winders big job? irish ae86 5 8,982 03-31-2011 08:39 PM
Last Post: Dogger
