Front big brake kit
02-22-2015, 12:29 PM
Front big brake kit
I would not recommend grp4. The kit that I bought for my 86 did not fit, the rotors. I gave them back the kit and they refunded me. I finally took the t3 kit that fit perfectly. I have just replaced my master cylinder by a Nissan tercel one to have a less spongy feel. I did not try the car yet.
my toyota is fantastic |
02-22-2015, 01:32 PM
Front big brake kit
I have fitted the GRP4 kit without any problem
02-22-2015, 06:52 PM
Front big brake kit
I'm not sure if they're available yet, but this kit looks amazing: http://www.modception.com/products/ae86/...-brake-kit
02-22-2015, 07:38 PM
Front big brake kit
When was that floss.ie? It seemed to work before but recently I do not think it is the case. You should have seen how they made the holes of the brackets. It was nasty. Glad it worked for you.
10-24-2016, 09:29 AM
(This post was last modified: 10-24-2016 09:29 AM by FanIsHere.)
Front big brake kit
(01-31-2015 10:45 AM)T_AE86 Wrote: If it can helps you: I use the "old" T3 Wilwood kit (basically the same of GPR4), i had a problem because my brake booster - BMC was zenki...a bit small than kouki, the pedal was too soft. I replace the BMC for a 1" Hiace's one (with starlet EP71 deposit because hiace's one touched the booster) and now is a bit hard...and works perfect!! Is the 1'' BMC from Hiace a plug&play one for Zenki's brake booster (2-bolts)? If yes, can I have the part number of it? Or at least the exact model of Hiace? ![]() Follow: The story of my AE86 |
| Big wheel problems | gh0st | 16 | 12,116 |
| 20v mains & big end bearing | izanagi | 9 | 12,545 |
12-26-2016 12:42 PM Last Post: pack |
| Toyota partnumbers OEM brake lines (front) | IBMFD3S | 6 | 8,663 |
01-10-2012 06:36 PM Last Post: bozu |
| changing from electric moter windows to winders big job? | irish ae86 | 5 | 7,727 |
03-31-2011 08:39 PM Last Post: Dogger |
| Brake master cylinder for FC3S brake conversion | Hachi Go | 8 | 16,354 |
03-03-2011 12:06 AM Last Post: filh |
![AEU86 AE86 - Front big brake kit [Image: AEU86 AE86 - Front big brake kit]](https://i.ibb.co/MhLrFLH/45782267-2164710247101236-2051748599338893312-n.jpg)
