Front Lights/Fog Lights
03-29-2009, 05:25 PM
Hi guys... I just got a 1984 Trueno AE86 with Kouki bodyparts, engines c/w wiring. Recently, I just noticed that the front fog lights could not be switched on (bulbs are all good). Tried to find the switch but nothing turn it on. AFAIK, the main selector switch on the dashboard is for the (1) front yellow small lights and rear lights, (2) main pop up headlights, and (3) to turn all lights off but remain pop up the headlight. I did find one more switch next to the defogger switch (P=) but when I switch it on, the same happen like when I turn the main selector switch on (1). So, I am thinking that the P= switch is for the fog light (white color on the end side of front bumper). Anybody knows anything about this? Thanks...
03-30-2009, 10:08 PM
Better check the fuses and relays in the engine compartment first, but otherwise you should be checking the input lead (I think the W-B) for the retractor relay on page 30 of the USDM wiring diagrams:
http://files.aeu86.org/manuals/ewd-ae86-...parrot.pdf
[Image: AEU86 AE86 - Front Lights/Fog Lights]
04-01-2009, 04:29 PM
Its actually Front Fog Lights (on the each corner of front bumper), not the Head Lights. Thanks anyway.
04-01-2009, 10:17 PM
Ah, I understand now! Big Grin
But those are not foglights: they are the indicator lights and this is how they should operate:
So if they operate when engaging the turn signal or hazard lights they should be working properly. Wink
04-02-2009, 09:37 AM
Thanks a lot for the info... Smile anyway, mine does not work like that at all... the white indicator lights did not operate even if i switch the signal/hazard light. May be i should check the fuse or something else aye...
04-02-2009, 09:44 AM
another thing on electronic/electrical... I got a digital dash/meter on my AE86. Since I got it from the last owner, the "Rear Lights" indicator on the digital meter panel is always turned on/shows up. All rear lights is working properly. Thanks...
  Can you seperate trueno kouki bumper lights into zenki bumper lights? gh0st 17 13,241 12-19-2021 11:58 PM
Last Post: gh0st
  Do UK/Euro cars have an illuminated fog light switch? Lauren 9 12,078 08-22-2011 08:53 PM
Last Post: Lauren
  Fog Lights Identification KameleonK 7 9,068 06-05-2010 10:34 PM
Last Post: KameleonK
  dash lights and park lights problems **Sigh** adamsaiyad 5 7,945 05-07-2010 01:21 PM
Last Post: adamsaiyad
  levin fog lights ae8286 4 6,584 08-29-2007 12:54 AM
Last Post: parrot
