Fluids
06-18-2006, 12:00 AM
Fluids
Hey.
I want to change all the fluids in my car like oil, brakefluid, coolerfluid, gearbox oil an whatever you got more. What fluids can you guys recommend me to buy? I'v got an 4AGE 16V engine in my car an im going to use the car for racing/drifting. I dont have a clue what to buy. ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. Toyota Corolla GT Twincam 1.6 16V (My new project )
06-18-2006, 11:23 AM
Fluids
We had a subject about oil a while ago:
http://www.aeu86.org/viewtopic.php?t=59 Dunno about the oils though, but reading the topic again gives me the impression most people use 10w40 (also for drifting/racing) and GL-4 for their gearbox and GL-5 for the LSD. But you'd better read the topic yourself and make up your mind there. ![]() And about brakefluid: http://www.aeu86.org/viewtopic.php?t=1306 For brakefluid I'd advise you to use dot 5.1 1983 - AE86 Sprinter Trueno - import project 2013 - Honda Civic sport - daily driver 2004 - AEU86 dot ORG - daily domain Support our forum, buy from the AEU86 shop:
06-18-2006, 12:32 PM
Fluids
Tnx, i will read the topic then.
Do you also know howmuch brakefluid you need? ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. Toyota Corolla GT Twincam 1.6 16V (My new project )
06-18-2006, 02:47 PM
Fluids
just buy a literbottle of dot5.1, some places sell it for reasonable prices.. if you just pump it through on each corner untill you see clean fluid you'll be good to go. Draining the brake fluid conpletely requires more fluid cause you'll need to do more bleeding. It also introduces the risc of breaking the master cilinder, which often goes bad when you try to refill the system (using the normal pumping method).
06-18-2006, 03:27 PM
Fluids
I want to replace the brake hoses for goodridge Stainless ones so when i remove the old one's the system will automaticly be drained.
so than i have to refill the complete system again. (please correct me if im wrong) ![]() Toyota MR2 2.0 16V Gen3 Turbo Toyota MR2 1.6 16V Toyota Corolla GTZ Twincam 1.6 16V (AE86) (Sold. Toyota Corolla GT Twincam 1.6 16V (My new project )
06-18-2006, 05:00 PM
Fluids
Your correct then..just make sure you're carefull with the bleeding if you do it manually.
![AEU86 AE86 - Fluids [Image: AEU86 AE86 - Fluids]](http://img186.imageshack.us/img186/2723/carb2ck1.jpg)
![AEU86 AE86 - Fluids [Image: AEU86 AE86 - Fluids]](https://www.aeu86.org/sticker-banner-468.gif)
