Final drive calculation.
12-24-2014, 09:09 AM
(This post was last modified: 12-24-2014 09:10 AM by assassin10000.)
Post: #31
FYI: Altezza Zenki was 4.1, kouki was 4.3 (TRD of course was 4.56)
I ran 4.88s on mine for a bit, as that is what my MA4x diff had when I did my BEAMS swap with a 5 speed W58. Thinking about going back to them for track use, as it puts my gearing pretty close to just right (I think). I'm currently on 4.56 and with the W58 it is pretty damn good. I also tried 4.3's and those weren't terrible, but not as good as 4.56 and nowhere near as fun as 4.88's. With the 6 speed, I'd vote 4.3's. Andrew |
12-24-2014, 03:08 PM
(This post was last modified: 12-24-2014 03:10 PM by Uzelac.)
Post: #32
(12-24-2014 09:09 AM)assassin10000 Wrote: [ -> ]With the 6 speed, I'd vote 4.3's. Even if 1st is usable, that wouldn't be a wise option since nobody goes 220+ km/h at track/stage. On that Aisin gearbox (S15, MX5 and IS200) 1st is pretty much unusable, so one need short FD to use it as 5speed gearbox, from 2nd to 6th .Btw. that also makes that gearbox kind of "dogleg" one ![]() I vote for a true SCCR gearbox for track/stage use with 4.778+ FD. For a daily, 6speed gearbox with FD in range from 4.1 to 4.778. |
| Gear end , drive pinion height | filh | 5 | 15,011 |
06-27-2013 12:29 AM Last Post: filh |
| 5.375 final drive ratio with stock T50 | 4000GT | 23 | 35,988 |
08-07-2012 01:08 PM Last Post: 4000GT |
| Final Drive ratio - need advise | KD2229 | 12 | 22,122 |
08-26-2011 08:33 AM Last Post: totta Crolla |
| U-joint on drive shaft - Beams 6s box | KD2229 | 3 | 6,975 |
08-18-2011 03:59 AM Last Post: KD2229 |
| guy with some questions about drive train. | projectfert | 4 | 6,776 |
06-22-2011 06:04 AM Last Post: projectfert |
