Error code 8, advice??
08-03-2008, 11:33 AM
Anyone had trouble with ae86 4age error code 8. Air inlet temp.
I have followed as the toyota books says but its all still the same. Any thoughts. Checked nearly everything imaginable, timing, wires etc etc Steve.....this is sparrrrrtan |
08-03-2008, 11:35 AM
Sorry double post
08-07-2008, 11:36 AM
1. Resistance of sensor approx 2000 Ohms @ 20 deg C (measured
at sensor with wires disconnected). 2. Resistance of sensor circuit with sensor connected, measured from ECU end while disconnected from the ECU 2000-3000 Ohms @ 20 deg C. 3. Voltage across sensor circuit with everything connected and ignition switched ON 2-2.8 volts. These tests tell you that the sensor resistance is in range, the wiring has continuity, and the ECU is applying the correct voltage to the sensor circuit. In theory, if you obtain the correct values, you should not be getting a no. 8 error code. If you are, then you may have to swap in a known good ECU to see if the fault is in your ECU. Cheers... jondee86 |
08-08-2008, 03:43 AM
Thanks Jondee ill look into it.
08-10-2008, 01:34 AM
jondee86 Wrote:1. Resistance of sensor approx 2000 Ohms @ 20 deg C (measured Just tested this and got 2000ohms jondee86 Wrote:2. Resistance of sensor circuit with sensor connected, measured from Did this also and got 3000ohms jondee86 Wrote:3. Voltage across sensor circuit with everything connected and ignition Also this and got 2.8volts. Is this test n# 3 correct thou Jondee, Toyota 4age book says between THA and E2 with IGN ON there shouldnt be any voltage between these 2. Which leads me too belive that something inside the ecu isnt operating properly. jondee86 Wrote:These tests tell you that the sensor resistance is in range, the wiring http://www.toymods.net/TechDocs/4age_book/efi/fi_45.jpg Number 1 test on there states No voltage, but i have 2.8 volts with IGN ON So far all efforts point towards a new ecu. Steve.....this is sparrrrrtan |
08-10-2008, 04:19 AM
Nah... you have good results for the tests you have done. If you refer
to the top band on the page, you will see that No Voltage in the third test is the Trouble condition, and that the STD Voltage is 2.0-2.8. The tests on that page are checking the ECU power supply and ground in case there is no voltage across THA and E2. Fault code 8 indicates Open or Short Circuit in the air intake temp sensor circuitry. First reset the ECU (disconnect battery and then put your foot on the brake pedal). If the fault comes back, it might be a good time to check that all your sensor plugs and wires are in good nick. A bad/loose connector or wire rubbing on a sharp edge, might be causing an intermittent fault. Cheers... jondee86 |
08-10-2008, 05:17 AM
jondee86 Wrote:Nah... you have good results for the tests you have done. If you refer I really wasnt looking forward to stripping the loom apart to find the fault. And when i try somethign new i always reset the ecu, poor thing has been reset about 8 times already Steve.....this is sparrrrrtan |
08-10-2008, 06:03 AM
Well well well i bypassed the loom completly for the tha and e2 wires straight from sensor to ecu and now i have no error in ecu, still running rich
Before with error code number 4 plug was normal but the rest of the plugs were black. Now with wires bypassed all plugs are black and she's still rough. Ill keep digging, maybe not ecu
08-10-2008, 11:18 AM
If its overfueling, probably pay to check your water temp sensor as
well. There are only a limited number of things outside of the ECU that can cause your engine to run rich... water temp low, air temp low, bigger injectors, high fuel pressure, air leak in the inlet manifold, variable resistor or O2 sensor. Thats all I can think of Good luck !!Cheers... jondee86 |
| 4age 16v running roughly - diagnostics shows unknown code | Ryo | 8 | 12,271 |
| Brake advice - master cylinder | mannix20vt | 12 | 20,192 |
| Engine advice needed | spill86 | 14 | 21,857 |
09-15-2015 10:43 PM Last Post: spill86 |
| coilovers advice | robotype | 23 | 31,219 |
05-21-2013 10:18 PM Last Post: Jan Pedersen |
| Advice needed on parts! | phill 92 | 5 | 7,780 |
03-02-2013 09:39 PM Last Post: Ivan141 |
Good luck !!
