Engine wont rev. Fuel pump?
02-27-2007, 07:10 PM
Understood.
Today i checked what I can find from the boot, and it was only "fuel level meter". I expected to find a fuel pump, but there were no hoses at all, just some wires. This is the thing I took of the tank from the boot side. ![]() Maybe someone of you have some pics of "removeing the fuel pump" process? (sorry for my bad english
White ae86 Levin |
02-27-2007, 08:31 PM
[quote="Nookie"]
This is the thing I took of the tank from the boot side. ![]() quote] holy crap you dont have a pump! problem solved lol, you have to drop the gas tank. its a long process if the tank is full. but quite easy to do. you can shoot power to the tank to see if its not a power issue first. the other wires by the ones you disconnected for the level are the pump ones. just make sure you are gettin 12vdc with power on. if not then drop tank and have fun. 1/4 tank or less is ideal. E is better. try not to drink petrol when syphoning. did you rule out spark?
02-28-2007, 03:15 AM
about 10 to 15cm closer to the front of the car is the pump mount... what you have there is the float. As EFI became more used, the combining of the float and pum p became the standard. In our OLDE cars... there are two assemblies that drop into the fuel tank.
That is why I DIDN'T say access the assembly from in the trunk(boot)... You MUST drop the fuel tank to get to the pump assembly. Dan - You can | OST Porting service - http://hachiroku.net/forums/showthread.php?t=19991 |
02-28-2007, 07:59 AM
I thought in was accessible from underneath the rear seats, or is that applying only for hatchbacks?
02-28-2007, 06:34 PM
I dont remember it being accesible from the inside in any ae86.. some people cut a bit out of the floor to gain access.
03-14-2007, 05:52 PM
How does Fuel pump's bracket (a thing, wich 'holds' fuel pump) look like? (maybe someone have some pics? post it here plz
White ae86 Levin |
03-14-2007, 07:42 PM
03-15-2007, 01:01 AM
Thank you!
White ae86 Levin |
03-15-2007, 02:46 PM
Ah right. That's what the thing in my shed is.
![]() When I bought the car from TE71Corolla it was between the old SR5 loom.
03-15-2007, 02:52 PM
Strange, SR5 use mechanical fuel pump...
It's bonus from some GTS I think |
| 20v BT - which oil pump? | Mylesmck | 4 | 5,990 |
| Fuel pump issue | DJexor | 11 | 11,664 |
| fuel line hose from the pump | Wikizz | 4 | 8,599 |
10-16-2017 07:11 PM Last Post: jdm86gtz |
| Raising the rev limit on stock ECU | fax0815 | 2 | 13,917 |
08-31-2015 02:04 PM Last Post: gon |
| 4age 16v oem ecu rev limiter research | ditn | 18 | 36,220 |
06-22-2015 08:02 AM Last Post: ditn |
![AEU86 AE86 - Engine wont rev. Fuel pump? [Image: AEU86 AE86 - Engine wont rev. Fuel pump?]](http://xs112.xs.to/xs112/07092/P2277047.jpg)
![AEU86 AE86 - Engine wont rev. Fuel pump? [Image: AEU86 AE86 - Engine wont rev. Fuel pump?]](http://i107.photobucket.com/albums/m291/vallius3/14032007281.jpg)
![AEU86 AE86 - Engine wont rev. Fuel pump? [Image: AEU86 AE86 - Engine wont rev. Fuel pump?]](https://www.aeu86.org/sticker-banner-468.gif)
