Engine problems! PLEASE help!
08-26-2005, 05:57 PM
Post: #31
Thats the oil pressure gauge...either it isn't working or you have a problem...
Hope it al turns out ok, but i fear for the worst.. A wheel to steer the front of the car A pedal to steer the rear |
08-26-2005, 08:06 PM
Post: #32
Have you wired the oil pressure sender correctly? You probably know where to find it, but just in case: the small metal bell shaped thing just under the distributor. A connector should slide over the round button on top of it.
08-27-2005, 12:00 AM
Post: #33
hai, it is connected but shows 0 oil pressure! yikees! i thought thats the oil level.. so i have no oil pressure... now what?
08-30-2005, 12:31 AM
Post: #34
Apolan Wrote:hai, it is connected but shows 0 oil pressure! yikees! i thought thats the oil level.. so i have no oil pressure... now what? Unscrew oil pressure indicator, an let someone run your engine with main ignition cable off ( your engine can't run, just reving ) and look at hole where you remove oil pressure indicator. If every thing is OK, when engine revs, oil must bleed. It not - oil pump. Another way, unplug oil cooler, an let someone run your engine, look for oil that cames from tube. 1984 AE 86 Levin hatchback 1989 AE 92 GTi 2004 Kawasaki KLE 500 CROATIA - small country for great drift |
08-30-2005, 03:37 PM
Post: #35
I guess you have some worn out conrod bearings! Beware of that because you may damage your crankshaft. Make a video with the engine running, it may help others to understand! But if the problem is what I suspect, the less you run the engine the better because it needs new bearings.
What kind of oil are you running? Thick oils and low oil pressure tend to wear out bearings. But hey, I'm no mechanic! You should get it seen by one! Good luck Best regards |
09-06-2005, 11:14 AM
Post: #36
im using castrol gtx 10w40.. remember engine was staying in the corner of previous owners garage for some 6 years or so..
kas what am i supposed to see when i unscrew the oil pressure indicator?? |
09-06-2005, 11:22 AM
Post: #37
2 apolan: it there is any pressure, oil would be comming out
09-06-2005, 03:04 PM
Post: #38
hehe, obviously. okay, ill try that.. but i think im about to get a hole engine rebuild underway..
does anybody know where to get all new gaskets, washers and seals when doing a rebuild the cheapest??.. what do i need? |
Big wheel problems | gh0st | 16 | 10,730 |
Starting problems 4-AGE kouki | Hanzo | 3 | 3,523 |
TUV RHD AE86 Germany (help please) | 4dori | 9 | 8,410 |
07-17-2019 07:42 PM Last Post: Hachigo83 |
Problems Mintex M1155 pads | Dino86 | 9 | 10,409 |
07-04-2017 11:22 AM Last Post: totta Crolla |
Carb question please help | MIGGZFSU | 3 | 5,509 |
03-29-2017 03:06 PM Last Post: MIGGZFSU |
