Engine out
01-04-2009, 09:27 PM
Engine out
Hello Fihl, too bad this !
Mecapower is solding an ae86 and has parts i think so you can contact him, perhaps he has somethings for you...
01-05-2009, 09:20 PM
Engine out
[u:5eaf559555]answering Didierae86[/u:5eaf559555] :merci , je vais le contacter , mais la dernière fois , il n'avait rien ,j'avais été cherché un bloc , mais trop usé et vilebrequin idem .
Thxs
Filh
Filh
Save the RWD cars
01-18-2009, 10:37 PM
Engine out
Some news :
I did some measurments ; the head chamber volume is :29cc. added to 0.8 headgasket and milled block , I think I've found the trouble cause .
All parts machined apart , and I did the assembling , but never measure the
compression ratio. I think it was over 13:1!!!!
That can explain the several pistons , broken between rings , and blue pistons pins !
What do you think of that ?
Filh
Filh
Save the RWD cars
  toyota a series engine....can a fwd corolla engine be used 210 datsun guy 5 11,154 10-30-2013 11:18 PM
  TRUENO HEADLIGHT PROBLEMS CAUSING ENGINE TO CUT OUT manhoolee2000 2 5,608 10-10-2010 11:27 PM
Last Post: Hachi
  Need engine,any engine Apolan 25 28,711 10-29-2006 06:55 PM
