Engine out
01-04-2009, 09:27 PM
Engine out
Hello Fihl, too bad this !
Mecapower is solding an ae86 and has parts i think so you can contact him, perhaps he has somethings for you... |
01-05-2009, 09:20 PM
Engine out
[u:5eaf559555]answering Didierae86[/u:5eaf559555] :merci , je vais le contacter , mais la dernière fois , il n'avait rien ,j'avais été cherché un bloc , mais trop usé et vilebrequin idem .
Thxs Filh Filh Save the RWD cars |
01-18-2009, 10:37 PM
Engine out
Some news :
I did some measurments ; the head chamber volume is :29cc. added to 0.8 headgasket and milled block , I think I've found the trouble cause . All parts machined apart , and I did the assembling , but never measure the compression ratio. I think it was over 13:1!!!! That can explain the several pistons , broken between rings , and blue pistons pins ! What do you think of that ? Filh Filh Save the RWD cars |
| toyota a series engine....can a fwd corolla engine be used | 210 datsun guy | 5 | 10,587 |
| TRUENO HEADLIGHT PROBLEMS CAUSING ENGINE TO CUT OUT | manhoolee2000 | 2 | 5,292 |
10-10-2010 11:27 PM Last Post: Hachi |
| Need engine,any engine | Apolan | 25 | 26,584 |
10-29-2006 06:55 PM Last Post: ZaX |
