Dual carb set ups - ?
11-17-2006, 12:13 PM
Post: #31
Hi Ben
Quote:The TPS adaption will be tricky, but not difficult........it will be harder to get the machining sorted if you dont have a machinist i would have thought.
I need to get an idea on how I can do it. Thankfully the old man who maintains my Fathers classics is very talented in machining his own parts so I will have a word and see if he can lend a hand.
For the vacuum feed plenum is any specific design needed, or do I simply need a small chamber of any size with 4 vacuum feeds going in and one coming out for the MAP sensor? Might have a go at bashing something together.
Quote:Regarding management.......IF you can get your OE setup running the ignition, i think it will work quite well as it will be a 3d map and it will be mapped specifically for a 4age.
Would the fact that its not adjustable ultimately limit the performance I can get? That’s the main reason why I am also considering some aftermarket solution; Just for the added adjustability.
Quote:I dont know the megajolt system, but i am not a fan of cheap management solutions.......they become time consuming and a pain in the ass.
Me neither, seems like a simple system using OEM Ford parts but I don’t know its limitations, for what it costs it may be worth experimenting with. Would a VEMS system be worthwhile, one consideration is that in the future for ultimate performance I may replace the Carbs for ITB’s?
Does anyone else on here have any direct experience with the Megajolt system? Does anyone else have any suggestions?
Cheers
James
[Image: AEU86 AE86 - Dual carb set ups - ?]
http://www.eight-six.co.uk - read the blog!
UK AE86 Forum - http://www.phpbber.com/phpbb/index.php?m...ghtsixcouk
11-17-2006, 12:25 PM
Post: #32
Hi Ben,
Another one for you …
Looking at the image of Ian B’s set up for the vacuum plenum and I am a bit confused?
Obviously the big black pipe is the brake booster and there are 4 orange pipes which are for the individual vacuum feeds for each throttle body.
There are also another 2 orange pipes with fitted ends on – I can see one goes to the map, but its T’ed off? What’s that for? The other runs along the bulkhead and disappears.
Is Ian running a stock ECU or an aftermarket ECU – just trying to work out if that vacuum feed is for the ECU or if its powering a vacuum gauge?
Cheers
James
11-17-2006, 06:05 PM
Post: #33
86 i think it goes to a sensor located on the OEM filter box (don't remember its name...) :wink:
  Carb question please help MIGGZFSU 3 7,309 03-29-2017 03:06 PM
Last Post: MIGGZFSU
  Changing distributor when carb 4age izanagi 14 22,831 07-04-2016 03:27 PM
Last Post: Uzelac
  Carb conversion but what is this and how ? Allexz 5 11,782 05-24-2016 08:48 AM
Last Post: Allexz
  Mikuni carb help just wont balance megabob 3 7,397 01-01-2013 10:32 PM
Last Post: allencr
  Carb'd 4AGE on Hyperpak ignition no spark problem 4AGE FORD 12 29,066 01-22-2011 11:03 PM
Last Post: 4AGE FORD
