Drifting with stock power on the dry
04-16-2007, 04:13 PM
hehe, that is why I use 13'' wheels (because I don't have any but those
SNO-MO-BIRU project started- CHIRO |
04-16-2007, 04:28 PM
Just out of interest,
Does any of you guys remember this guy called Zax that sometimes posts on this forum? 8Kg front, 6Kg rear springs, shortstroke KONI shocks, a modified double rear strut bar and a dying 4AG in the front. Stock LSD Stock engine, if it was still doing 110Hp it would have been a miracle Sideways 24x7 at Mobikrog, snow, ice, dry, wet, it didn't matter. http://www.go-drift.com Damn I miss that white hachi of his.... Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-16-2007, 04:40 PM
| Drifting with stock power on the dry | |||
04-16-2007, 11:14 PM
just looked at your video.. nice job..
but i see that your car is a little bit soft.. in German: Schwammig.... maybee some Buschings and a Tanabe Stabilizer set yould do good work... With the camber you could get it drifting befor the turn starts.. so it wouldn't be a power over drift...
04-16-2007, 11:28 PM
nice drifting!
04-17-2007, 12:06 AM
bushing kit will come this winter, stabilizer from whiteline i think will do their job well
04-17-2007, 09:31 AM
not shure about the whiteline stabilizers... Studebaker from München has them and he is not satisfide... He even thought the OEM ones were better... but maybe he has a different driving style then you do...
04-17-2007, 10:58 AM
ash hearing the revs in your car you are not near 6600 ? Drifting a stock hachi mostly takes it upto 7000 rpm and alot trying. But first I would recommend a difrent learning spot. This corner is pretty long and your speed at entry must be much higher.
Its not safe to learn drifting on these long corners. Try a parkinglot or a small corner. Start in first gear 90 degree turn before you try these long ones. You might hurt yourselve Cars: "99 Lexus IS200 "86 AE86 Kouki Panda Levin GT-Apex (restore project) "84 AE86 Zenki Blue Levin (project racer) Motorcycles: "02 Yamaha R1 "02 Honda Hornet S "08 BMW R1200GS |
04-19-2007, 10:40 AM
Ash,
Watch this vid: http://www.go-drift.com/video/go-drift.com_9V.wmv Skip the first minute or so, thats just parking lot fun, the real stuff starts after that. ![]() there is also a topic somewhere from HRC with a vid of him on this same track, also with a near stock hachi with only upgraded suspension. Greetz, Bastiaan "mux213" Olij Moved down under, no more hachi |
04-19-2007, 12:16 PM
Seems like his throttle is stuck in the open position
| Best setup for drifting... | Okami | 68 | 108,661 |
01-19-2012 11:20 PM Last Post: Okami |
| Drifting Lelystad New Vid check bottom | Okami | 9 | 19,248 |
03-14-2011 10:47 PM Last Post: Okami |
| DRIFTING IN ROMANIA | spawns | 5 | 11,125 |
09-09-2010 01:32 PM Last Post: spawns |
| Indie feature documentary on drifting – calls for stories | emptykingdom | 2 | 10,156 |
05-18-2010 12:05 PM Last Post: Okami |
| What do you like about drifting...? | heshan | 1 | 5,251 |
09-27-2009 06:51 AM Last Post: heshan |
