Dimensions wheel studs?
03-04-2007, 05:58 PM
Just discovered that one of my rear wheel studs broke off, causing rattling sounds while driving. One half of the stud is still in the hub/brakedisc. Can I just remove it by tapping it out from the front?
Okay but my reallll question was...what are the dimensions of the wheel stud?? couldnt find it... (I have standard 14" pizzacutters, if relevant) Any (Dutch) shop you guys recommend?? (something like this http://www.biesheuvel.nl/shop/cat/71/stud_bolts ?) also..do i need remove the brake disc and all the other things to change the studs? If i know these steps beforehand, hopefully it wont take too long
An '86 86 driver Zenki AE86 Levin coupe |
03-04-2007, 10:01 PM
I have front wheel stud on my desk now.
03-05-2007, 11:02 AM
so 25.5 mms protrude out from the hub? If one bought 25 mm spacers with 4x100 studs, would this spacer acomondatte for the studs to be bolted down/hidden?
03-05-2007, 11:16 AM
Yes, Apolan. That's why I always recommend 25+mm thick wheel adapters.
In fact sometimes 20mm ones can work also. |
03-05-2007, 12:32 PM
Thanks for picture Jamiemirror!
03-05-2007, 12:42 PM
Thanx man!
03-06-2007, 08:01 AM
Hey, guys keep this to yourselves, but one day jamie will conquer this world, i'm certain of it... no jokes.
[/offtopic] |
03-06-2007, 10:35 AM
wtf ???
05-19-2009, 01:16 AM
jamiemirror Wrote:I have front wheel stud on my desk now. Is this stock stud ? 10x |
| Quick question - Brake Pad Dimensions | Lt86 | 2 | 6,378 |
06-07-2015 12:08 AM Last Post: jondee86 |
| Dimensions clutch master cylinder | bozu | 2 | 7,300 |
04-16-2015 07:11 AM Last Post: bozu |
| Spindle dimensions, backing plate bolt pattern | Rascal21 | 18 | 25,965 |
03-13-2014 11:45 AM Last Post: Rascal21 |
| ARP Head studs in a N/A engine, necessary? | Jimmi The Kid | 13 | 17,822 |
02-04-2013 11:27 PM Last Post: Jimmi The Kid |
| Sump Guard dimensions | Dino86 | 4 | 6,292 |
03-14-2012 02:18 PM Last Post: Project D |
