Different ECU of AE86 ? ? ?
03-09-2006, 07:23 PM
Hi,Sorry fir my english...
I have 3 ECU (89661-12060 * 175700-0051 12v )for AE86.
Today I have open this Ecu and in the interior is different...
The number is the mircrochips is differents...
What the difference ??pourquoi?
1)
[Image: AEU86 AE86 - Different ECU of AE86 ? ? ?]
2)
3)
03-09-2006, 08:40 PM
I heard from Robokill the Zenki and Kouki ECUs are different.
03-10-2006, 08:32 AM
Yep....nr 1 and 3 are zenki ECU's.. I have one in my drawer here so I'm pretty sure.
03-10-2006, 09:13 AM
As far as I known the ECU sends difrent signals in a kouki than in a zenki.
The engine can start but when it goes to the ecu to keep the moter running it dies. Simply because some sensors are difrent.
03-10-2006, 11:11 AM
sorry about the off topic , but can someone point in those pictures the crystal that have to be changed to raise rev limit ?
thank you
03-10-2006, 12:25 PM
Probably the little metal casing on the bottom left (near the CPU).
03-10-2006, 01:25 PM
Thank you
I think I will be able to do some testings on this crystal, I will post result if i get any Smile
03-10-2006, 05:39 PM
ok,thanks
ZENKI and KOUKI is the same thing (Performance)??
I can assemble ECU KOUKI in my AE86 ZENKI???
03-10-2006, 07:18 PM
Performance is similar, they are not interchangeable..
03-11-2006, 01:06 PM
Does the main MCU chip say 151801-0481 on all three ECUs?
If so I would guess all three are the same and will be interchangeable.
The fact that the 89661-12060 number is on the lid of all three backs this up. (unless the lid has been swapped)
If you change the MCU crystal frequency you will also affect the fuelling and ignition timing slightly.
What country are these AE86 ECUs from?
  Using a different diff in an AE86 megabob 6 11,417 02-17-2015 03:37 PM
Last Post: megabob
  Different seats for AE86 - Help needed Uzelac 15 23,430 03-24-2009 09:40 PM
Last Post: Mike N
  Different cam duration Thor W 3 5,239 02-10-2008 11:05 AM
Last Post: Thor W
  Different RNP types (SR5 open/GTS open/GTS LSD) nmwisima 10 14,282 03-19-2007 11:15 PM
Last Post: 20vWill
  T50 dogbox, different gear ratios etc info needed jamiemirror 4 7,223 06-25-2006 11:28 AM
