Diagnostic port
04-24-2010, 05:23 PM
Diagnostic port
Hey guys.. Where is the diagnostic port where I could connect the laptop to find out the Error Codes?
If anyone could help me out that owuld be Great!
thanks,
Heshan.
Cheated on my いたずらな女の子 and now I can't get enough of her..
04-24-2010, 06:15 PM
Diagnostic port
It is on the firewall, but you can not connect it to the laptop.
Check the codes from here: http://www.troublecodes.net/Toyota/
# Before proceeding, make sure the:
* CHECK ENGINE light circuit is functional. It should be ON when the ignition switch is ON with the engine stopped.
* Battery voltage is above 11 volts.
* Throttle valve is fully closed (Throttle Position Sensor IDL points closed).
* Accessory switches (A/C, etc.) are OFF.
* Engine is at normal operating temperature (if possible).
# Turn ignition switch to ON position.
* Do not start the engine.
* Place a jumper wire across TEl and El terminals in engine check connector.
# Count number of flashes from CHECK ENGINE light.
* If system is operating normally (with no detected faults), the CHECK ENGINE light will blink continuously
and evenly about 2 times a second.
# Otherwise, the light will blink a number of times equal to the trouble code as follows:
* The light blinks only (.5 second ON, .5 second OFF) when indicating a number.
* The light will be OFF for 1.5 seconds between the first digit and the second digit of the code.
* If more than one code is stored, the light will be OFF for 2.5 seconds before the next code is displayed.
* Once all code(s) have been displayed, the light will be OFF for 4.5 seconds and then the whole sequence will repeat.
# The diagnostic code series will continue to repeat as long as the check connecter terminals TEl and El are connected.
# When finished, remove the jumper wire.
# After repairing the malfunction, clear the codes from the ECUs memory.
[Image: AEU86 AE86 - Diagnostic port]
"Tämmösellä modernilla autolla, niin mun mielestä, ei tämmöstä kisaa voi ajaa. Tää käy kunnon päälle eikä riitä aivot tähän touhuun!"
""With a modern car like this, in my opinion, a competition like this can't be driven. It's too physical and your brains can't cope with this stuff"
-Henri Toivonen 2.5.1986-
http://www.youtube.com/watch?v=OwgB4Xs4LVQ
04-25-2010, 12:55 AM
Diagnostic port
Or you can stay on aeu86.org, and download the factory diagnostic manual!
http://www.aeu86.org/index/technical-ae8...topic=5158
Thumbs up!
04-26-2010, 03:33 AM
Diagnostic port
a great help!
Heshan.
04-27-2010, 04:10 AM
Diagnostic port
http://www.aeu86.org/viewtopic/car-teste...ol/t/10075
-=Trueno ae85 SR 3a-gze=-
  4AGE Big port head failure Blaze0010 3 1,225 01-23-2026 03:35 PM
Last Post: totta Crolla
  Small Port Swap Alex170984 1 5,929 11-21-2016 01:46 PM
Last Post: Alex170984
  Small Port 10.3 Pistons Alex170984 1 5,878 10-25-2016 09:18 PM
Last Post: oldeskewltoy
  Help! Diagnostic connector (IGN) for dataloging with MS? Bean 2 5,639 05-24-2011 11:07 AM
Last Post: roman
  4age intake side (port) dimensions Uzelac 15 41,961 03-03-2011 12:43 AM
Last Post: Uzelac
