Cusco adjustable top mounts on Konis problem
07-02-2008, 12:23 AM
Hi guys
I know this was mentioned before but was not able to find the thread.
I just wanted to fit some Cusco top mounts onto my Koni dampers but the top screw is too big.
What was the solution to this??
Thanks for your help.
Speed Industries
Hurdnerwaeldlistr. 73
8808 Pfaeffikon
Switzerland
e-mail: [email protected]
phone: +4155 420 15 69
page: http://www.speed-industries.ch
MSN: [email protected]
We have all the parts your Hachi needs
07-02-2008, 12:43 AM
had that problem......
just find normal nut's (not long ones) but with the locking bit or use loctite
[Image: AEU86 AE86 - Cusco adjustable top mounts...is problem]
with the T3 camber plates, i used smaller nuts on that picture.
but some time after i machined the camber plates a bit so that the locking bit actually touches the thread.
07-02-2008, 01:07 AM
Did you just machine the existing nuts down?
Isn't it having some kind of play this way?
Speed Industries
8808 Pfaeffikon
Switzerland
07-02-2008, 10:55 AM
i did the same, without the bit going inside the camberplate, never had any problems with play at all Smile
07-02-2008, 01:04 PM
it's not the camber plate that was machined (or the nut) it's a spacer that the T3 camber plates have between the shock absorber and the camber plate.
never had any problems with play with both solutions
07-02-2008, 04:23 PM
@speed inc
In verbindung mit den konis brauchst eigene muttern, ich schau dir zuhause mal nach, vielleicht habe ich noch die teilenummern bzw. die abmessungen von Tein.
07-02-2008, 04:28 PM
M12x1,25
07-03-2008, 10:52 AM
Vielen Dank Ash
I see if Cusco has something matching.
Speed Industries
8808 Pfaeffikon
Switzerland
  Red top in the ae86 gh0st 25 23,549 08-08-2022 08:43 PM
Last Post: gh0st
  Replacing Top Windscreen Moulding chrisae86 2 4,475 06-18-2022 08:56 PM
Last Post: chrisae86
  Cusco Powerball Headers on a NA 4AGE 16V? JDMitch 11 27,609 05-01-2021 10:09 PM
  Build your own adjustable fuel pressure regulator ;) oldeskewltoy 8 27,152 08-19-2018 12:08 PM
Last Post: AlexKTM
  Early tvis red top from e9 gti small or bigport? Ryo 3 10,124 04-20-2018 09:14 AM
